Rear Differential Drain
Old Mar 27, 2012 | 04:34 PM
  #61
Aardwolf's Avatar
Aardwolf
I believe the stink in gear lube is sulfur which can turn to sulfuric acid. I have read some FSM say not to change it and some state 100,000 miles. If your car still has the original, just change it.
I use Redline heavy shock proof, I still have the original D36 and it still leaves posi marks. You can check break away torque by turning the spindle nut with one side off the ground.
I've been planning to add a drain since I change mine fairly often. I put on a lot of track miles! Getting it tested isn't a bad idea but I like to learn things so it would be cool to me to know.
Old Mar 27, 2012 | 05:08 PM
  #62
corvetero's Avatar
corvetero
Can be possible that my C4 LT1 92 has a drain plug from factory? Actually leaks a little for that plug
Old Mar 27, 2012 | 07:35 PM
  #63
93Rubie's Avatar
93Rubie
Originally Posted by CDN/AZ LT4
Nathan, you could not have said it better. I find the C4 section to be the most informative of the entire Forum and it's because of a bunch of guys who don't mind sharing their knowledge and expertise with guys like me that are not as skilled or knowledgeable. It's not difficult to sort out the guys who've been there, done that and have the expertise, certified or not versus the relatively smaller group that feels the need to provide an opposing opinion just because they want some air time or need to get their post count up. I'm by and large a lurker that enjoys this forum and don't usually make comment. It' because of the knowledgeable guys here that I tackle small jobs on my C4 that I otherwise would be intimidated by. To you real experts who have walked that mile and have the expertise please don't desert us.
Excellent post. Your the type of person, who I'll bend over backwards to help. Why, cause you got the right attitude, and you want to learn.
Old Mar 28, 2012 | 01:07 AM
  #64
Cliff Harris's Avatar
Cliff Harris
I learned a lot of stuff by working on my car and studying the FSM.
I also learned a lot of stuff by saying things on here that were wrong, either out of ignorance (didn't know about the vent) or because I forgot something that made a difference. I hate it when I'm wrong and put out bad information. Fortunately there are knowledgeable people on the forum to correct me...
Reminds me of something I saw years ago:
"You have the ability to learn from your mistakes. You will learn a lot today."
Old Mar 28, 2012 | 11:24 AM
  #65
DAVECAD2.0's Avatar
DAVECAD2.0
NO. At least not with a Dana 44. I have one, and I installed it.
Old Nov 7, 2012 | 12:32 PM
  #66
mixalive's Avatar
mixalive
Would anyone be interested in posting the template for drilling the drain hole? I have all the bits and tap. Just could use the template..
Old Nov 7, 2012 | 01:03 PM
  #67
WVZR-1's Avatar
WVZR-1
You don't need a template. See this post for contours of the "floor" of both the D44 and the D36.
http://forums.corvetteforum.com/c4-t...questions.html
Old Nov 7, 2012 | 01:17 PM
  #68
mixalive's Avatar
mixalive
Excellent.. Thanks..
