Race Car Engine Build
Old Apr 7, 2012 | 05:41 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Originally Posted by jaa1992
Yep. He probably kept the caps the way they are for budget reasons.
I'll bet he isn't going for a huge HP build, probably in the 300 - 350 rwhp
I have the same problem, but I'm not adverse to a dyno reclass.
I'm going to be around 3400lbs (driver and splash of fuel) and MAX 350 rwhp with a 383. One of the reasons I went with a Hotcam instead of a cusom grind.
Now I'm still planning the replacement engine for the 383 in case it blows. I'll be using my original LT1 for that one.
I don't think we are allowed splayed caps. We have to use a stock type block for our model year and all L98's came with a 2 bolt block. No where in the rules does it say that you can add 4 bolt caps, so if it doesn't say that you CAN then you CAN'T.
I am building for about 370 HP to the wheels and about 3158 comp weight with me and fuel in the car.
Old Apr 7, 2012 | 08:46 PM
Kubs's Avatar
Kubs
I also have a question regarding rod bolt torque. What are the specs for a lubed rod bolt? The bolts are ARP 8740 high tensile strength, if it makes a difference. I believe lubed torque is around 45 ft/lbs but wasn't 100% sure.
Edit: These are the rods I got
http://www.summitracing.com/parts/SCA-26000716/
The only specs on rod bolts I could find on the ARP site were for kits to add to rods. These rods came with these bolts and I dont know what kit they are from.
Old Apr 8, 2012 | 01:01 PM
rklessdriver's Avatar
rklessdriver
Those rods should TQ to 65LBS.
SCAT sends bolt specs in the box or a label on the box.
Will
Old Apr 8, 2012 | 02:18 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Will
My Scat Rods came with the 7/16X1.4" ARPs and the spec on the box was 64LBS with maximun stretch of .0046".
Old Apr 8, 2012 | 07:39 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
St. Jude Donor '12
I thought the corvettes all got 4 bolt mains L98 and LTx?
If you are using points don't forget the freaking tire width
TTC is only a 255 and that is the widest tire you can run without taking points.
My reclass last year gave me at least a TTB 265 as the widest tire so the 275 was only +1 pt.
Old Apr 8, 2012 | 07:55 PM
rklessdriver
LTX in the Y body are 4 bolt main.
L98's are all 2 bolt main reguardless of what platform they came in.
There are factory 4 bolt roller cam blocks, which came in GM 3/4 ton commercial trucks (ie Cube Vans) or over the counter crate engines (ie ZZ3/4).
Will
Old Apr 9, 2012 | 12:27 PM
Kubs's Avatar
Kubs
Will
Thanks guys! I thought I looked in the box and didnt see anything, but I did not check the outside very carefully. Maybe my machinist took it out when he balanced everything.
Unfortunately no. I am planning on a 275mm tire with no dyno reclass. We will see how it goes at first. I have a couple back up plans in case I need to change things to go faster.
Old Apr 9, 2012 | 05:11 PM
ScaryFast's Avatar
ScaryFast
Will - confirm that torque number is with moly grease under the bolt head, correct?
I think my ARP rod bolts were higher. 78 ft*lb comes to mind. I'll look when I get home.
Old Apr 9, 2012 | 05:12 PM
ScaryFast's Avatar
ScaryFast
Is your back up plan a C5 or C6? C4's are not fast
Old Apr 9, 2012 | 05:41 PM
Kubs's Avatar
Kubs
No that is not the backup plan. That would be the primary plan if it were an option.
Old Apr 9, 2012 | 05:43 PM
rklessdriver
7/16X1.4 ARP 8740 cap screw = 64lbs with ARP moly lube.
http://www.scatcrankshafts.com/scatt...rque_specs.pdf
Will
Old Apr 9, 2012 | 08:11 PM
Kubs's Avatar
Kubs
Will
Great link! I will try and go to the shop tomorrow after work and see if i can find a torque on the box.
Old Apr 9, 2012 | 08:37 PM
  #33
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Good luck, its your car.
Old Apr 10, 2012 | 01:40 AM
  #34
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
The box will have the same data as the pdf Will posted. It may also include the maximum stretch column as mine did.
Old Apr 10, 2012 | 11:22 AM
  #35
ScaryFast's Avatar
ScaryFast
Will
Thanks!
Old Apr 10, 2012 | 11:46 AM
  #36
Dr.Huxtable's Avatar
Dr.Huxtable
Dangit, i hate when you get to the bottom and there's no more pics Awesome work, can't wait to see the outcome
Old Apr 10, 2012 | 12:12 PM
  #37
Kubs's Avatar
Kubs
Should be more pictures this weekend. I plan to get the rest of the pistons in, and possibly the cam this weekend.
To Race Car Engine Build
Old Apr 11, 2012 | 09:44 AM
  #38
Kubs's Avatar
Kubs
Thanks Will and Ray! The torque was right on the box like you guys said it would be. I can't believe I missed it before. I got 3 more pistons in last night for a total of 4. All are torqued to 65ft/lbs.
Old Apr 11, 2012 | 11:18 AM
  #39
billybonesmusic's Avatar
billybonesmusic
When you went to the ARP studs for the crank, did you send it back to the machinist to re-bore the main caps?
Old Apr 11, 2012 | 12:36 PM
  #40
Kubs's Avatar
Kubs
I bought the studs prior and sent them with the block to the machinist. He did a line bore with them in place, yes.
