Race Car Engine Build
Old Oct 24, 2012 | 10:18 PM
  #121
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Originally Posted by red L98
Hey are you using the dash cage or just the dash pad ?
Just the pad. The dash will bolt to the studs on the top of the trans tunnel and to the bottom of the dash pad. Nothing else is behind it.
Originally Posted by 96GS#007
tsk tsk tsk -20hp for you. Gotta have both. Sponsors expect in-car footage so dash stickers are mandatory for the full power gain
Well I'll have to put some inside so i can get my 20HP back!
Old Oct 24, 2012 | 10:42 PM
  #122
red L98's Avatar
red L98
[QUOTE=Kubs;1582163728]Just the pad. The dash will bolt to the studs on the top of the trans tunnel and to the bottom of the dash pad. Nothing else is behind it.QUOTE]
Cant wait to see how that turns out , You think you can cut another panel without the gauge holes if i like the way it turns out ?
Old Oct 25, 2012 | 09:01 AM
  #123
Kubs's Avatar
Kubs
We'll see how it turns out. If you pay for the aluminum and shipping I don't think it will be an issue. I'll be sure to take pictures of how it mounts as well.
Old Oct 25, 2012 | 10:16 AM
  #124
RUU's Avatar
RUU
Originally Posted by Kubs
This is what I hope the final product will look like:
Where's the plug for your iPod?
Old Oct 26, 2012 | 09:19 AM
  #125
Canam's Avatar
Canam
Hey Kubs, here's a pic of my racecar dash if your looking for ideas. I can post more if you want.
Old Oct 26, 2012 | 12:50 PM
  #126
Kubs's Avatar
Kubs
Thanks for the pic, but I already have something in mind. I would like to keep the curves of the later style dash.
Old Oct 26, 2012 | 05:22 PM
  #127
TJM's Avatar
TJM
I would suggest getting some plexi-glass and doing the first try with that.
It's cheap and forgiving. We did that in the '84 dash.
We did four before we where happy with the fit.
Likely going to go aluminum now that the mounting and vibration issues are apparent.
Good winter project for the kid.
Old Oct 31, 2012 | 09:41 PM
  #128
red L98's Avatar
red L98
Cool thanks budd ..
Old Nov 1, 2012 | 11:08 AM
  #129
LD85's Avatar
LD85
The guy that made the pedal mounts can water jet any combination of patters you like, let me know if you need his info.
Old Nov 1, 2012 | 12:20 PM
  #130
Kubs's Avatar
Kubs
I already have the outline cut out, I just need holes for the gauges now. I will likely do that myself, but PM me his info just in case. I may use him for other projects.
Here it is in aluminum:
I am still playing with the layout (using paper gauges) but I should be cutting holes this weekend.
Old Nov 1, 2012 | 12:31 PM
  #131
Aardwolf's Avatar
Aardwolf
It doesn't look like you are adding a cage and it doesn't look like the wave shaped metal between the cowl is there like on mine. Did some years not have that? I left it there since I thought it may help chassis rigidity. Perhaps adding one would be of benefit?
Pic of the part I'm talking about:
I weighted it and posted that in the weight sticky thread, I think it was seven pounds. It's the large part right in the middle about the DIC.
The heater core surprised me in how much heat it helped remove from the coolant. And the blower helped a lot with defogging the window, and helmet visor.
Old Nov 1, 2012 | 12:33 PM
  #132
Aardwolf's Avatar
Aardwolf
If you need blinker indicators or some other warning light I got some LED's from Ebay, $2 and they are bright!
Old Nov 1, 2012 | 12:36 PM
  #133
Kubs's Avatar
Kubs
It will get a cage before it is raced, just not right now.
Mine did not come with that middle wave section, and it looks like my column mount is different as well.
Here are some older pics as I was removing stuff:
Old Nov 1, 2012 | 12:59 PM
  #134
Aardwolf's Avatar
Aardwolf
Huh interesting, that is a lot different!
Old Jan 22, 2013 | 02:32 AM
  #135
red L98's Avatar
red L98
Any update on the dash ... Looking to cut down some weight .
Old Jan 22, 2013 | 12:10 PM
  #136
Kubs's Avatar
Kubs
Sorry man, I haven't done much to the car since Thanksgiving other than mount the switch panel. My wife and I are trying to buy a house right now so the race car has been on the back burner. At the very least I will try to get a template mailed out to you before too long.
Here is the switch panel:
Old Jan 22, 2013 | 02:35 PM
  #137
red L98's Avatar
red L98
That would be great budd ... I see your Boxing it in . Good luck with the new house.
Old Jan 24, 2013 | 03:43 PM
  #138
ScaryFast's Avatar
ScaryFast
I see you're running a tach that goes to 10k RPM. Aren't you running an L98 still? They make ones that go to 6 or 7k...
Old Jan 24, 2013 | 05:28 PM
  #139
Kubs's Avatar
Kubs
Not in Carbon Fiber!
Yes its still an L98. Redline should be around 6500 ish.
