I have been super busy on other things lately but here are some pictures of my coolant tubes. I just cut the OEM hoses and put the the tubes in where they needed to go. All the wiring is done, just need to finish the dash and install gauges before trying to start it.
Looking Good I'm assuming you added a "ridge" inside of each end of the tube in order to ensure hose retention?
Looks good !
Its nice to see someone else with the same approach... I elimenated 90% of the hose on my street Vette long ago. All it took was blowing an inacessable hose in the middle of nowhere and I saw the light. Even got a flushing adaptor built in, that doubles as a purge/air vent.
BTW,.
the build looks as professional as any I've seen. Good looking engine bay...looking forward to hearing about the "trials".
Good luck
Looks good !
BTW,.
Good luck
Thanks for the compliments guys! I tend to be pretty **** about appearance, and am a little embarrassed with the dust on the engine/engine bay in these pictures. It will be clean before I drive it.
For the tubing, I made my own bead tool since I didnt want to spend a ton on a bead roller. The reason I didn't post a picture at first was because it doesn't look very good, but it is functional.
Looks good. When will you be able to get it on the dyno? I am interested in seeing the numbers with your air intake. Do you figure to have more cooler air when drawing in from this point vs from the nose area? Also, when they weigh the cars for your power to weight ratio, does the car weight include the driver?
Cool man!.. all you need now is an air foil and a hypertech chip for 40 more HP.
Oh I knew I forgot something!!
Really? I mean Really? How can you forget the most important hp device....stickers
I got plenty of those too!
I hope to get it on the dyno around spring time. Its starting to get cold up here in Ohio so my main goal is to get it out on the street to seat the rings, and do some data logging to send to my tuner. When I feel the tune is spot on then I will go to the dyno. Im a curious about the numbers as well.
The reason for the rear facing intake is to take advantage of the high pressure area in the cowl. At speed it creates a ram air effect. The class I was originally building for had strict rules, and in a nut shell I was not allowed any forward facing holes that provided air to the intake. This way is not forward facing, but I get the same benefit. Now that class has been changed and I can do pretty much anything so its not needed, but still cool.
When NASA weighs the cars competition weight includes the driver, all gear, and any fuel in tank when finishing the race.
I started making a template for the dash today. Believe it or not that one piece of poster board took several hours to make. Now I need to lay out my gauges and cut it out of aluminum.
This is what I hope the final product will look like:
