Help major electrical problem
Old May 15, 2012 | 12:19 PM
glava2876's Avatar
glava2876
Default Help major electrical problem
I can't imagine what is going on, but I have a major elctrical problem -the story goes like this;
I have never had any big electrical issues with my 84.
I had been driving it all week before I went on vacation a week ago and left the Vette in my garage.
When I got back I put in the key and it was DEAD -nothing at all.
I put a charger on it and it just HUMs like a dead short and nothing even flickers, so I pulled it right off.
I have a Bosch battery that is maybe a year old and have never had any problems.
The last thing that I did to dissrupt the electrical was about 3 weeks ago I unhooked the battery when I put a new chip in, but the car had run great from that time until I left for vacation.
What do I look at first??
Old May 15, 2012 | 12:42 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
A real dead battery seems to require a kick start before the battery will start taking a charge. I find putting the charger in crank or high amps, for about 10 minutes, then back to low amps, gets it going.
After you get charged, you can start checking for the drain, using your amp meter between neg terminal and battery cable.
Old May 15, 2012 | 01:09 PM
glava2876's Avatar
glava2876
I had it on a trickle charger for about 5 hours yesterday and it did nothing.
So, I tried my larger charger and got the results above; it draws real hard and there isn't even a flicker from the inteior lights -should I just leave it on?
Thanks,
Glen
Old May 15, 2012 | 01:10 PM
ch@0s's Avatar
ch@0s
Thanks,
Glen
It sounds like you should take that battery in for replacement.
Old May 15, 2012 | 02:05 PM
glava2876's Avatar
glava2876
I may do that to have them check it out.
Maybe I should just leave it on the charger for a while to see if it will take some charge, i just thought that I would at least have the interior lights at least flicker when i put the charger on it.
Old May 15, 2012 | 02:35 PM
ch@0s's Avatar
ch@0s
Well if you haven't tried another battery it could be a loose connection or bad cable. If you take your battery in they will test it for you then you go from there.
Old May 15, 2012 | 03:10 PM
toptechx6's Avatar
toptechx6
When a battery is that low I'm not a big fan of charging it when connected. Save yourself additional aggravation and disconnect the negative cable, charge the battery then reconnect.
Old May 15, 2012 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Thanks,
Glen
If it's drawing current to battery and you don't see a flicker of interior light, it sounds like you need to clean and tighten both battery terminals.
What is the battery voltage ?
Old May 15, 2012 | 05:00 PM
glava2876's Avatar
glava2876
Ok, I need help.
Here is the update.
The car was running perfect, with 1 year old Bosch battery.
I parked it in my garage and went on a one week vacation.
Came back and the car is dead.
Trickle charged about 4-5 hours yesterday -nothing.
Tried to hood it up to my large charger and it peged the needle just like when you touch the 2 leads together.
I just tried leaving it on the charger and the charger trips out.
Is there any logical major short or other electrical component failure that could do this without popping a fuse in the vehicle and how could it have been fine when I left?
Old May 15, 2012 | 05:17 PM
3D87C4's Avatar
3D87C4
The thing is, if the battery drains far enough that one or more cells is fully discharged when you try to charge it those cells can get reversed. This is fatal to the battery.
Old May 15, 2012 | 05:21 PM
86vette1sttimer's Avatar
86vette1sttimer
7th Gear
Disconnect the battery and hook the charger to the car. If the lights come on the battery has a dead short.
Old May 15, 2012 | 05:52 PM
glava2876's Avatar
glava2876
Great idea, I just disconnected both cables and it is charging.
I'll let it auto charge over night.
The cable ends were a little corroded, so I cleaned them up.
I'll try hooking it up in the morning to see what I have then.
Thanks,
Glen
Old May 15, 2012 | 06:34 PM
cuengineer's Avatar
cuengineer
Sounds like you are on the right track. One additional thing I have noticed depending on what charger I use is that if a battery is relatively low in voltage, the charger will start to charge and then act like the battery has a short and trip off. Apparently, this is a safety mechanism in my newer chargers that have electronic controls that check the voltage of the battery as it charges and also show the % of charge. What I have had to do a number of times is to hook up my old charger for a time to get the voltage up some and then change out to my newer charger that will not over charge the battery which I prefer to use. It is kind of an aggravation though. As stated above, you do want to make sure that you have a good battery as it is about the cheapest thing and more likely to be a problem than about anything but connections/cables.
Old May 16, 2012 | 03:08 PM
glava2876's Avatar
glava2876
Thanks,
Glen
The charger meter did do some weird things when I put it on and then it did swing over to the area indicating a low battery, but charging.
The battery took a full charge overnight.
Hooked up the battery this afternoon and everything is back to normal!
I'm still not sure why it went dead in just a week -I had another vacation in March and no problem that time.
The only thing that happened between the two vacations is that I had disconnected the battery to install a new chip.
The positive cable did seem a little loose when I took it off yesterday, so maybe I wasn't getting a good connection or full charge?
The DIS volt check indicates 14.7 v now.
I also watched as I closed the hood and the under hood lights are turning off OK.
I guess I'll have to just wait and see.
Thanks to everyone that took the time to respond -it's a bummer when you can't drive your Vette!
Old May 16, 2012 | 03:11 PM
illenema's Avatar
illenema
Scary stuff.
Old May 16, 2012 | 03:16 PM
AGENT 86's Avatar
AGENT 86
That's all it takes to make a battery seem dead. You may not have a drain at all.
Old May 16, 2012 | 04:50 PM
ch@0s's Avatar
ch@0s
Good news Cheap fix
Old May 17, 2012 | 04:11 AM
Cliff Harris's Avatar
Cliff Harris
Batteries can die instantaneously. My most dramatic example was when I went to the gas station and filled up. When I tried to start the car it was absolutely dead -- no lights, clicking or anything. The mechanic measured the battery and it only read about 5 volts. New battery fixed it.
To Help major electrical problem
