BBK Sticking Throttlebody
1. Better, smoother idle
2. Cruise control is now smooth & even, with the BBK it was always speed up & slow down. It was so bad I quit using the cruise.
3.Tailpipes no longer have black sooty residue on their edges.
4. Totally different, (better) throttle response in all rpm ranges.
There are no unfavorable things to tell. I just can't believe this whole thing, I actually thought my BBK was giving me my money's worth. I should stress that nothing was changed on the car except the tb so there were no other factors in the improvements.
To be fair,
Good points about the BBK tb,,, it makes a nice paperweight.
I'm done with this P.O.S.
Any suggestions on where I should get a rebuild from?
Anybody know anything about this ebay seller?? http://www.ebay.com/itm/TPI-52mm-bor...3e816f&vxp=mtr
Tony
The magnaflow catback has been great..
I would be more than happy with a 48mm TB.. but I don't see to many that are NOS, or even rebuilt..
After searching high and low.. I figured that 52mm is the only way to go. I even tried posting here for help on rebuilding.. but it seems to be something that not many people do.
Tony
Good Luck
Royal pain in the butt.
I called BBK and they want me to return my unit, and they will only fix it if they find it defective.. So.. yay.. No car for another however long it takes those bozo's to discover the problem, and probably make excuses.
You would think a large company would just send you another one.. I think i'm going to order the reman from ebay.
Screw BBK. And the junk they sell, to be honest, after us all sharing our experiences on their product, I don't even want that crap on the end of my plenum.
Now that the three of us have told the world about our BBK tb's we won't even be able to sell them.
Hmmm, doorstop, maybe?
Everywhere i've checked, it states its for an F-Body Chevy TPI setup.. Anyone using this??
Tony
I work with metal for a living, and i'm thinking its probably the aluminum, or the casting process they use. I did notice some perosity (small holes in the metal) on the bored surfaces.
I personally think that BBK contracted this out to the cheapest manufacturer in China, and are getting what they paid for. I am in the process of returning mine because I don't believe BBK can send me a product i would ever be happy with.
Believe it or not, the metal composition of something like this is a huge factor. I doubt that anyone who has purchased this new design from BBK has it working 100%.
The original GM casting is probably the best you're going to get these days, and if you have a small one man operation (guy in his garage or small shop) reboring and rebuilding these units, that is truly the best you are going to get. If you compare the BBK to the stock unit, its much beefier, and totally different design. More metal = more heat buildup.
If I was an american citizen, i'd be looking into a class action lawsuit against BBK.
Honestly, if you're thinking about a new throttle body, be sure to not buy a BBK. You will be wasting a whole lot of time, money and aggravation.
I wouldn't say that they did a great job on re-tapping the 2.5mm screws, some were pretty light on threads, but at this point i'm happy that I have a corvette without the throttle sticking on me.
So as I said in the previous posts.. STAY AS FAR AWAY AS POSSIBLE FROM BBK.
Customer service wanted me to return the unit, wait for them to assess/fix and then return to me.. no thanks, for $400.. I want it working outta the box, the design is terrible as well, I personally think they cheaped out on materials, and in the process of re-inventing the wheel they failed. The way they mount the bearings to the throttle shaft is an absolute fail as well. Aluminum bore had perosity.. etc, It was way to bulky as well.. (Mine was the one piece design)
Good luck to anyone who buys that unit!
