Engine missing on 93 LT1
Old May 25, 2012 | 08:15 PM
senter9's Avatar
senter9
Default Engine missing on 93 LT1
I have replace the opti-spark, plug wires, plugs, also had the injectors rebuilt, replace 02 sensors and cats but still there is a miss. Any ideas EGR valve possibly. thanks
Old May 25, 2012 | 09:25 PM
93Rubie's Avatar
93Rubie
When does the miss occur, hot, cold, warm, cool, under heavy load, idle, light load,etc....
Have you done any tests other than replacing parts?
Is the car ever hard to start?
Codes?
Do you have a FSM?
Old May 25, 2012 | 09:33 PM
TheMonge23's Avatar
TheMonge23
Have you looked around the garage to see is the engine is hidden under a tarp or blanket? Try thinking about the last place you saw your engine and back-track from there.
*sorry for the useless post, but based on the title it had to be done*
Old May 25, 2012 | 09:38 PM
pcolt94's Avatar
pcolt94
In addition.
Just for a starting point, if the miss is during idle, start pulling plug wires or injector plugs and see if you can localize it to a cylinder. Then you might be able to find a problem. Also look for a wire sparking to ground.
Have you done a compression check?
Old May 26, 2012 | 01:22 AM
senter9's Avatar
senter9
The miss seems to be in closed loop not when I first start it but within 30 sec or so. Also code 43 ESC/knock sensor and 32 EGR system fault. I replaced the parts trying to get the car to pass CA smog. It passed with the cats. The miss is still there. I first thought the miss was at idle but when they were testing for smog at 2500 rpm I noticed the miss. Cant tell when driving.
Old May 26, 2012 | 08:02 PM
93Rubie's Avatar
93Rubie
The knock sensor should not cause a miss. If the EGR is sticking open it could cause a miss. I would pull it and see if it is very carboned up or sticking open.
Old May 26, 2012 | 08:50 PM
HlhnEast's Avatar
HlhnEast
Even the noOb got it, I love it when a sense of humor comes together
No offense on the noOb, just new to us. Welcome humor master!
To Engine missing on 93 LT1
