1985 cold start
Old Jun 10, 2012 | 11:17 AM
msledge50's Avatar
msledge50
Default 1985 cold start
Hello, I have a 1985 corvette with 49,000 original miles.And my last full tune up was ayear ago. But the last week or so it's been harder to start when its sets for 6 or more hours. But when its warm it starts right up. When I say hard to start it will crank 3-6 seconds, sometimes as much as 8 seconds. But every now and then when it's cold its starts right up. Any ideas. THANKS.
Old Jun 10, 2012 | 12:46 PM
1986coupe's Avatar
1986coupe
How old is the fuel filter?
How strong is your battery? Coil?
Any vacuum leaks?
Old Jun 10, 2012 | 01:24 PM
msledge50's Avatar
msledge50
250 miles on new fuel filter. Battery is good, Stater is new it was change 3 weeks ago. Coil was I think was all changed during my last tune up. But I gotta check with my mechanic to be sure.
Old Jun 10, 2012 | 01:26 PM
msledge50's Avatar
msledge50
[QUOTE=msledge50;1581036220]250 miles on new fuel filter. Battery is good, Stater is new it was change 3 weeks ago. Coil was I think was all changed during my last tune up. But I gotta check with my mechanic to be sure. No air leaks.
Old Jun 11, 2012 | 02:33 AM
Cliff Harris's Avatar
Cliff Harris
Might be a problem with the cold start injector.
Check the cold start injector, the wiring and the cold start temperature switch on the front of the intake manifold. It has a connector that looks like a fuel injector connector.
Old Jun 11, 2012 | 08:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you hear the fuel pump run for 2 seconds when ignition is turned to run ?
Old Jun 25, 2020 | 11:00 AM
chevy john's Avatar
chevy john
Cruising
Default Hard start
It doesn't like ethanol. Put some ethanol cleaner from Gumout every now and then, that should fix it up.
Fix mine first bottle with a long drive.
To 1985 cold start
