coolant temperature sensor
Old Jul 13, 2012 | 03:27 PM
smeds's Avatar
smeds
Default coolant temperature sensor
Can anyone help with a question about the CTS in my 1988 corvette L98.
I would like to test the sensor, I am having problems with the coolant fans not turning on.
thanks for your help
Old Jul 13, 2012 | 04:13 PM
lkl2005's Avatar
lkl2005
Not exactly related but my low coolant light comes on sometimes. Is the sensor for coolant in the over flow res. tank?
Old Jul 13, 2012 | 08:36 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Before doing anything with the CTS, did you test the fan fuse ?
Is there 12v on the large red wire at main fan relay ?
Old Jul 13, 2012 | 09:54 PM
rodj's Avatar
rodj
Is in the radiator below the pass side hose
Has green wire going to it
Have you burped your cooling system to remove air bubbles that trigger the low coolant sensor?
Old Jul 14, 2012 | 01:51 AM
Cliff Harris's Avatar
Cliff Harris
The coolant temperature sensor that the ECM uses is located on the front of the intake manifold. You can measure its resistance according to this chart:
I have found that the low coolant light can come on if the radiator cap is bad. It is caused by the coolant not flowing in and out of the overflow tank the way it ought to.
Old Jul 16, 2012 | 11:22 AM
smeds's Avatar
smeds
Thank you everyone, I checked the CTS temp in accordance with the ohms on the chart and found everything to match up. I also have burped the system already and I do have 12V on the main relay wire. The fan fuse also checked out okay which led me to the ECM.
While testing connections there I found that that the tan/wht wire from the relays does NOT go to the ECM, instead it goes through the C207 connector which ultimately leads up under the dash.
I believe my problem lies in this C207 connector not making the right connections. If anyone has a pinout for a 1988 corvette it would be greatly appreciated. Thanks.
Old Jul 16, 2012 | 12:37 PM
smeds's Avatar
smeds
The wiring layout of the C207 is as follows:
(A) - BROWN
(B) - BLACK
(C) - BRN/WHT
(D) - TAN/WHT
(E) - WHT/BLK
(F) - PNK/BLK
(G) - BLACK
(H) - TAN/BLK
(J) - ORANGE
(K) - BROWN
(L) - NOT USED
(M) - BLKWHT
(N) - ORG/BLK
(P) - PURPLE
(R) - PPL/WHT
I just need to know each wire's function to fully resolve this issue.
Old Jul 16, 2012 | 05:41 PM
AGENT 86's Avatar
AGENT 86
[QUOTE=smeds;1581327266]The fan fuse also checked out okay which led me to the ECM.
While testing connections there I found that that the tan/wht wire from the relays does NOT go to the ECM, instead it goes through the C207 connector which ultimately leads up under the dash.(/quote)
My info is from my 86, there is no tan/white wire on fan relay and I don' t recall 88 having one either.
Are you sure you are testing the main fan relay ?
Old Jul 16, 2012 | 06:46 PM
smeds's Avatar
smeds
Yes, I have tested both and both check out though the TAN/WHT wire in position D on the relay routes to the C207 connector.
My problem is that I do not have a drawing identifying which each wire on the C207 corresponds to and therefore cannot establish that the opposite end of the C207 is mating correctly.
Old Jul 16, 2012 | 07:32 PM
AGENT 86's Avatar
AGENT 86
Still don't think you are testing the fan relays and I don not know of connector 207. Where are you getting your info ?
Where are the 2 relays you are testing ?
Old Jul 17, 2012 | 05:52 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The main fan relay is located on the rear of the LH fender well under the master cylinder. It's pin-outs are:
A - Blk/Red -> coolant fan
E - Red -> fusable link D
D - Dk Blu -> C100 -> C.Fan Fuse
F - Dk Grn/Wht -> C100 -> C237 -> ECM C1
BTW, C207 connects the Ign Sw: C1 to Fuse Block: A/C Fuse & C Fan Fuse & Pwr Wdo Circuit Breaker.
Old Jul 17, 2012 | 12:35 PM
smeds's Avatar
smeds
Yes, I am certain both relays are perfectly functional.
The issue I believe I am having is that the wire running through the C207 is not reaching the fuse block under the dash. If i could find out what each wire in the C207 corresponds to I believe I can resolve the issue quickly.
The C207 is a part of the wiring harness that runs through the firewall to the ECM, however it does not go to the ECM it branches off and runs under the dash, several wires including the one for the fan relay go through this circuit to the fuse block.
Old Jul 17, 2012 | 03:18 PM
AGENT 86's Avatar
AGENT 86
I'll ask again, where are the 2 relays your are testing ?
65Z01 posted the wire colors for 88, there is NO tan/white wire on cooling fan relays, yet you continue with telling us the relays are perfectly functional and have a tan/white wire going into C207.
65Z01 also posted the route of ECM wire to relay "F" - Dk Grn/Wht -> C100 -> C237 -> ECM C1
He also posted that " C207 connects the Ign Sw: C1 to Fuse Block: A/C Fuse & C Fan Fuse & Pwr Wdo Circuit Breaker".
Wake up and smell the coffee
To coolant temperature sensor
