Viper rear may be stronger but all the other parts attached for a 10 sec ride will probably take a dump.
Many hav tried over and over and eventually post they wish they went to a straight axle the first time they broke. They really dont handle much worse than an IRS unless youre a road course fiend.
I RARELY take my car down the 1/4...and I see no point in making a car that is DESIGNED to road race one-dimensional.
The next weak link beyond the IRS are the outer spindles...and there are solutions for that as well.
I understand that if you put slicks on and VHT on the track and dump the clutch, D44's will die. But don't think an IRS can't reliably do low 9's in the quarter.
We have one guy in our region do it regularly in his C3...thousands of passes each year. Not apples to apples, but it is IRS vs. IRS.
Do you have a light idea of what's required to get into the high 10's ? (Parts List and $budget$)
What's the plan (if you are planning something and i believe you are ! ) to get there ?
I would like to go with a stroker LS1 and a procharger, stronger trans, and a stronger IRS, I found a C5 full IRS for 2k on fleabay. Do you think the 4l80e will be good enough for road course etc. Or should I just get a t56?
Also what do you guys do about the notorious bubbling fuel tank in the C4's? When I first got it, it could hold about 16 gallons and at my last fill up it holds around 12-13 gallon. I was thinking having a new fuel tank made without the liner inside. Thanks all for your help
The C5 guys running 10s got a whole bunch of money in those trannies and rearends. If they are doing it on stock ones they wont hold too long.
Even getting in the 11s they start breaking, 3rd gear likes to go too.
True, going fast requires LOTS of money, its fun but it's expensive
You have a hell of a project there ! cool to know !
Cool if you do and my hats off if you end with what you want
that's the way to go , i hope you post all the upgrades
and goods and bads of this starting venture , i would start
with an all-motor power LSX monster , but i think you'll end up
going solid .- Hope to see you soon with a new thread showcasing your updates !
I had a feeling the rear and trans won't hold very strong, but the C5 IRS will be a good starting point I think.
Thank you, I know most people would say go the c5 route. But this was/is my first car so it has sentimental value and would rather keep the car and upgrade it.
BTW , i like you , what's your name?
You have the spirit, but are you ready ?
Will be a long journey ,you will need time (if you do the wrenching)
patience for test-fail , and money (lots) , i started here around 2007.
It's 2012 and still stubborn breaking parts and trying to upgrade ! lol !
It's been 5 long years but i love each and every experience that my 87
has brought to me, plus i have met many good friends here.
Tell us more , how long you have your 87 ? What you like most , drag racing
or autocross, this looks like an interview but i like this thread and i would love
to see your 87 kicking and haulin serious azz !
ps : i have never seen a c5 rear on a c4.- Not saying it can't be done
i have never seen it. solid is the way to go with your desired power.
i've just upgraded from D36 to D44 and i want to stay there.
Youll spend a LOT I mean a lot beefing up the C5 trans and rearend to take that abuse. Think carefully...dont let emotion/purist stuf get in the way of good sense.
Been there !
trying to add my quote of reality here too !
Aaron (AKS Racing) is a guy that runs low 9s all the time on c4 IRS. He even runs stock halfshafts. I think he either has a pinion snubber or modified the snout of the D44 to prevent twisting.
I've seen that turbo C4 many times , i love it !
But ...what did he do to his IRS?
Or maybe he rebuilds it once a year ?
We don't know
Has AKS blew his D44 anytime ?
i would love to know too !
We don't know
I have a 89 Vette with 650 RWHP and last year I finally put a solid rear end in it with a threelink system with a watts bar on it. I autocross my car almost every weekend and love it. I can no drag race whenever I want without fear of breaking. I tried everything to try and keep the Dana 44 together but was breaking something at every other autocross.
There will always be "a few guys" out there that somehow theirs live
Most the rest will break a lot. Seen them cryoed, hardened every trick in the book, still boom. Hope you have better luck thats all.
IIRC AKS' secret is to go softer off the line to minimize shock then it runs hard up top. It has enough power to 60' under [for example] 1.4 but he keeps it way over that to help it live.
If your dead set about keeping a IRS in the car, and willing to spend some bucks, have you considered the 9in, independent rear setup that is being made for the 2010 and up camaros? http://driveshaftshop.com/blog/?p=131
The c5 has the transmission and rear all in one unit, I would think it would take alot to adapt that to a c4. But unless you can fabricate the mounts, etc, yourself, ill bet you will be north of $10,000.00 with either of these setups.
Reason: to add link
13 years of bracket racing my 94 M6 440RWHP/440RWTQ LT1 with 4.09 gears. No problems with IRS. Have the treated Ujoints and spindles FWIW. Going with the Hoosier drag radials has helped run low 1.6's 60' with the tire pressure at 25PSI. Launch at 1500 RPM's with lite spin of tires for burnout.
Taken the approach to ignore all the trash talk and hype at the track and focus on running running 11.3-11.5 1/4 mile and 7.3-7.5 1/8 mile. Trying to knock off another .2-.3 to get in the 10's or 6's seems to push the IRS over the limit for a C4 IMHO
