no spark please help
Old Apr 20, 2013 | 12:22 AM
juggalo1788's Avatar
juggalo1788
6th Gear
Default no spark please help
I need some help I have a 86 corvette that has a no spark issue it was running perfectly fine then I put new intake base and runners pulled the dizzy out put everything back together got the car running then it died no spark put a new module in it still no spark put a new dizzy in it no spark I have then since. Checked everything there is power at the coil its just not going to out the cap. no codes either. Rotor is spinning too I don't no what's left any help would be great it just died one day driving and wont start back up please help
Old Apr 20, 2013 | 07:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is some info and diagnostics from my 86 service manual.
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
This should help narrow down the problem so you only replace/repair the failed part.
