new 383 build
I had to weld an o2 bung in the collector,
If you go that route you end up with a complete new engine block, you can put your original engine in the garage and its always there for the future ?
But if your keen to build one yourself, then go for it !
i put it in the oven for 15 mins at 120c and it screwed in pretty easy !
next up is the oil pump, summit have a high volume pump kit that its specifically for the corvette sump, its actually a Melling HV55 with a welded on pick up. I got a ARP chromoly shaft too,
With that crankshaft, piston and rods, that I linked to, will I have to have the block machined for rod and crank clearance?
Yes, the block needs to be machined and clearanced for the 383 crank throw, find a machinist near you that knows about building one, you can get that done when the bore and hone etc is done, ask the forum for suggestions if you dont know one yourself,
I would have a look at the Scat 383 sets also, they have some good combos that include bearings and everything you need, maybe 200 - 400 more than that Eagle kit but money well spent
need to get in there and clean it up a bit too !
I have finished the "upside down" stuff now, new engine mounts on, sump on using a 1 piece gasket and studs, and all the other sensors etc on, ready to turn it over,
flipped back the right way, time for the heads to go on, I am using a Cometic multi layer head gasket, its a .040 thou thick, 4.060 bore gasket, these are a strange looking setup, they are 3 pieces rivetted together, they arent actually bonded, but are recommended for a high compression engine, I will be running 11.1:1 with the .040 gasket.
you can see that the head gasket is pretty tight on the bore, and thats a good thing, it gets rid of "bad quench" in the engine, this is a subject that comes up every time people talk head gaskets.
the lube on the underside of the bolt is so the head can turn against the washer without binding so the torque is more accurate.
using the edelbrock info sheet, torque down in three steps, 40 - 55 - 65 ft. lbs. of torque.
if you look at the picture of the oil pump on post#45 you can see the sump gasket is back from the stroker clearance machining so i was confident it was going to be ok
I have got some new alloy rocker covers and giving them a test fit, whether they fit when the engine is in the engine bay or not, who knows ?
for the people who have changed to this type of rocker cover without the oil inlet, what is the best way to get the oil into the engine ?
Subscribed
