new 383 build
Old Apr 22, 2013 | 07:46 AM
blackozvet's Avatar
blackozvet
Default new 383 build
announcing a new arrival, weighing in at 200 kg !
I have decided to have a 383 short rotating assembly built and shipped as its cheaper to do that than build one yourself in australia, I will fit the roller camshaft and other parts then use the heads and top end off the 350 engine, and show some photo's along the way.
Eventually I want to directly compare the performance of the 350 versus the 383, as it will be a short engine only swap. The only difference outside the short engine will be 30 lb injectors and upgraded chip.
The 350 is out and being stripped, (let the fun begin !)
Old Apr 22, 2013 | 11:04 AM
weaselbeak's Avatar
weaselbeak
very exciting time
Old Apr 22, 2013 | 12:08 PM
Aaron Keating's Avatar
Aaron Keating
Congratulations!
Old Apr 22, 2013 | 01:13 PM
tunedport85inject's Avatar
tunedport85inject
wow that bad boy has flown from USA to Australia...200 kg by air!! enjoy it
Old Apr 22, 2013 | 03:01 PM
383vett's Avatar
383vett
Are the water passages in the head epoxied? If so, how does water get into the intake manifold?
Old Apr 22, 2013 | 03:34 PM
WW7's Avatar
WW7
Old Apr 23, 2013 | 04:37 AM
blackozvet's Avatar
blackozvet
I was wondering what you meant, then i looked at the photo and it looks like it has been epoxied, but its just the reflection of the flash on the brown water stain ! I was running 50/50 coolant/water, Adelaide water is sucked out of the Murray river and tends to leave a brown sludgy mark
it was via sea container, and my local shipping agent died when the engine was sitting at the SF wharf, took 5 months to turn up
Old Apr 23, 2013 | 04:49 AM
blackozvet's Avatar
blackozvet
Well I found that pushrod I lost in the engine last October !!
These chevy engines are tough - I lost the pushrod into the valley on a club run, found a couple of second hand ones from a local and kept driving another 350 km,s before getting home, and then another 5 months after that !!
Old Apr 23, 2013 | 06:45 AM
tunedport85inject
Yeah,by air mail it would cost you two eyes
We have a friend in Hamilton NJ that usually ships our stuff.he makes his business,but as a favour,takes our stuff into his container for a token price. Then he ships to Europe,where i live.I'm planning to have a 383 shipped this summer for next winter project.i was palnning a Blueprint engine.Looking at your brand, Tristar,i've seen its good stuff.They use Dart heads,or ,Dart blocks and heads,multiple choices for cams and very good price.
Old Apr 23, 2013 | 07:38 AM
blackozvet's Avatar
blackozvet
Well I cant comment on how good the engine is till I drive it, but I can say that the service from Tristar engines was excellent, I dealt with Ben Steine and he was great, the engine was built and ready to ship 2 weeks after I ordered it
Old Apr 23, 2013 | 03:21 PM
tunedport85inject
Nice, a good place for business! At the moment i'm waiting a container with my new tires,in Europe,i'm saying in all Europe ( C E), i can't find a vendor with 255/50/zr16 (stock 85 tires)...congratulation for your build
Old Apr 24, 2013 | 04:37 AM
blackozvet's Avatar
blackozvet
The old engine is stripped and off the engine stand, the new engine is on and painted,
It is an 010-350 block with 4 bolt mains, .030 over,
Scat 3.75 stroker crank, Scat 4340 I beam rods and Icon forged alloy 11:1 flat top pistons.
next step is the retro roller cam install.
Old Apr 24, 2013 | 05:27 AM
gerardvg's Avatar
gerardvg
Great combination enjoy the final assembly and installation
Hmmmmmm i just remembered i have not changed the engine number yet on my registration, been more than half a year since my 383 was fitted.
PS. she is the wrong color... should be black
Old Apr 24, 2013 | 06:49 AM
blackozvet's Avatar
blackozvet
I dont even have an engine number, the block has been decked too much !
p.s. it was black, but now its the right colour, red
Old Apr 24, 2013 | 07:14 AM
tunedport85inject
it seems to me to be orange... ...but a stock C4 engine is painted factory black... again"de gustibus non est disputandum" i like the orange chevy classic
Old Apr 24, 2013 | 10:27 AM
strotter13's Avatar
strotter13
Im doing the same thing. Any ideas thoughts or suggestions for converting my L98 350 to a 383 stroker?
Old Apr 24, 2013 | 07:12 PM
Dr.Huxtable's Avatar
Dr.Huxtable
You should stuff a 3.875 stroke in that baby while you have it apart. 13 more cubes for no extra $$
To new 383 build
Old Apr 24, 2013 | 09:05 PM
strotter13's Avatar
strotter13
When looking at the rotating assemblies, I see that some are balanced and some are internally externally balanced. Which one you I go for and why? What does it mean if it is unbalanced, balanced externally or balanced internally? Here is what I am looking at purchasing, which should I buy?
http://www.jegs.com/p/Scat/Scat-Chev...rPage=90&rpp=1
What camshaft would you guys suggest. I need a camshaft that will give me a boost in low end torque.
Finally I am debating putting aluminum heads, or rebuilding my stock heads and having them ported.
What are the advantages of buying aluminum heads, over using the stock iron heads? Thanks.
Old Apr 24, 2013 | 09:09 PM
strotter13's Avatar
strotter13
http://www.summitracing.com/parts/lu...ages/year/1985
Any thoughts on this cam? Thanks for any help.
Old Apr 24, 2013 | 09:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Internally balanced is better esp if youre going to be hard on it/rpms
Porting/going through stock heads vs new aftermarket usually a losing propsition. $$ vs results
With stock valves about 220-230cfm is all youre going to see out of the L98 heads. What are you doing about induction (intake)
oops edit-If you have the iron heads dont bother putting a penny into them.
