new 383 build
Old May 8, 2013 | 05:10 PM
  #61
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Can't you use the breather holes? That's how I fill my "Corvette" script-cover models.
Old May 8, 2013 | 09:50 PM
  #62
strotter13's Avatar
strotter13
Are you using a chip with the larger injectors? Did you have to upgrade your fuel pump or pressure regulator?
Old May 9, 2013 | 04:24 AM
  #63
blackozvet's Avatar
blackozvet
I was looking at the baffle plate under the hole and thinking it would be pretty restrictive, or maybe i just to need to accept it will take a while longer than normal and be patient ??
Old May 9, 2013 | 04:32 AM
  #64
blackozvet's Avatar
blackozvet
Yes, I have sent my Fastchip back to Ed Wright to be reburnt, he sent me an email last night saying it was on its way back.
I am running a 255 LPH fuel pump and adjustable regulator.
Old May 9, 2013 | 04:35 AM
  #65
blackozvet's Avatar
blackozvet
Originally Posted by tunedport85inject
probably an electric oil pump using the oil dipstick tube,this is what i use to flush engine oil without removing oil pan plug...
I was wondering about getting it in first
Old May 9, 2013 | 02:50 PM
  #66
tunedport85inject's Avatar
tunedport85inject
it fits into dipstick ... and does its work (very slowly so you can take a beer...)you can find some proof pump in your mechanic shop...
Old May 9, 2013 | 02:57 PM
  #67
tunedport85inject
Hi Black...can you give me some info about Ed wright your tuner...in Europe its very hard find someone working on this old obd1 stuff,actually i'm learning a lot about my 870 and Tunerpro RT,preparing myself for future tuning,but ,at the moment i would like to have someone able to tune my 870.From PCMFORLESS site i see they don't list anything for your 85 HLH 870 ecm,they starts from 86-89 165 stuff...so if there is someone that works on our one year stuff it would be great.Let me know something..a link or email ..thanks
Old May 10, 2013 | 05:11 AM
  #68
blackozvet's Avatar
blackozvet
not too many tuners want to know about the 85, here is a link to his website
http://www.fastchip.com/Index.htm
Old May 10, 2013 | 10:09 AM
  #69
GREGGPENN's Avatar
GREGGPENN
Now you know why most guys name their cars with female names!
Old May 10, 2013 | 08:10 PM
  #70
blackozvet's Avatar
blackozvet
might have to get that assembly lube out again !!
Old May 20, 2013 | 04:52 AM
  #71
blackozvet's Avatar
blackozvet
Well for one reason and another I have had a week out of the shed, but I did continue to spend money on the car !
Time to get back into it, need to give the lifters an oil bath and fit them in,
Next up, clean and fit the pushrods, I have gone with the Compcams magnum chromemolly 7.30" ,
big tip at this stage, make sure the oil pump shaft is engaged into the oil pump, much easier to do this now than when the engine is in the car !
Old May 20, 2013 | 05:46 AM
  #72
blackozvet's Avatar
blackozvet
I have ditched the steel roller tips and bought some Compcams 1.6 alloy roller rockers
I did a test fit of the stud girdle but they hit the breather baffle plate, so i will leave them off for now,
I have touched up the intake gaskets to match the ports, and held them in place while i put the RTV silicone on the walls.
Old May 20, 2013 | 10:50 AM
  #73
strotter13's Avatar
strotter13
Looking beautiful!
Old May 21, 2013 | 07:24 AM
  #74
blackozvet's Avatar
blackozvet
Looking beautiful!
Thanks mate !
I have set the rockers and fitted up a new PCV set up, and put the water pump on,
i swapped the engine from the stand to the hoist to fit the flexplate, next problem is the change from 153 to 168 tooth flexplate (forgot about that), starter motor doesnt fit how silly of me to think i could get thru this week without buying more parts !
Looking at a mini starter if anyone has any experience with those ?
Old May 21, 2013 | 09:53 AM
  #75
cv67's Avatar
cv67
St. Jude Donor '05
Ministarters are awesome. The clockable type even better opens up lots of clearance.
Old May 21, 2013 | 12:28 PM
  #76
GREGGPENN's Avatar
GREGGPENN
I'm dying to paint (or powder-coat) that intake for you!
Old May 21, 2013 | 08:04 PM
  #77
blackozvet's Avatar
blackozvet
looks like the mini starter is the way to go,the old starter is close enough to the headers now, i can get a 3 hp one for $125.
To new 383 build
Old May 21, 2013 | 08:06 PM
  #78
blackozvet's Avatar
blackozvet
if you said "polish" i would send it to you right now !
Old May 21, 2013 | 11:26 PM
  #79
cv67's Avatar
cv67
St. Jude Donor '05
oh man dont torture yourself with polishign the base. Powdercoat is the way to go
Old May 22, 2013 | 08:33 PM
  #80
Jymmeye's Avatar
Jymmeye
Your flex plate is also an external balance. Just checking.
