Gear upgrade
Old Jul 28, 2013 | 03:23 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default Gear upgrade
Ok I want to upgrade my rear end gear from a 2.59 to a 3.73. The car is a 93 auto. It is going to be a daily driver and may be go to the track every now and than with street tires. Not to often may be two or three times a year. Is this change possible with a 2.59 carrier or do I need to upgrade to a 3 series carrier? I read some other posts and confused myself. I just want the bottom line. Again I will only have regular street tires, nothing real sticky.
Old Jul 28, 2013 | 04:46 PM
JimGnitecki's Avatar
JimGnitecki
I've answered all but ONE of the questions you are asking in my recent post "Jim G's "new" convertible". Do a search!
In my case, I want 3.54, not 3.73, and Richmond Gear makes a 3.54 gear set specifically to use in a 2 series carrier on the D36 Dana we both have.
Jim G
Old Jul 28, 2013 | 05:14 PM
vetteOnTheRun
Jim G
Thanks for responding Jim. I did do a several searches and with the combined info I think I just confused myself. I did see these parts on the Richmond website 3.54: 49-0143-1 and 3.75: 49-0110-1. Looks like I will be looking for the 3.75: 49-0110-1 for myself.
Old Jul 28, 2013 | 05:22 PM
JimGnitecki
I'm sure you have a reason for wanting the 3.73 versus the 3.54. I just wanted to mention to you that the 3.54 allows you to hit 40 mph in 1st at redline, whereas the 3.73 will hit redline a little bit lower, at 38 mph.
Also, at 60 mph, the 3.54 give you almost exactly 2000 rpm, and the 3.73 will be about 2100.
Finally, the 3.73 will, I suspect, need a smaller pinion than the 3.54, since the ring size is limited by the carrier. The 3.54 has a 13 tooth pinion (with 46 tooth ring), so I suspect the 3.73 will be a 12 tooth pinion with a 45 tooth ring. The 12 tooth will be a bit noisier than the 13 I think.
I wasn't sure if you had done the math or not.
I had no idea which gear manufacturer currently has the best quality, but I read recommendations for Richmond Gear at two different forums, and Richmond makes this particular 3.54 gear set here in America, so I went Richmond. Last time, on a Chevrolet SSR retro pickup, I went with Motive Gear, and it came out loud enough that the aluminum driveshaft made it "sing" above 30 mph, necessitating a different, composite driveshaft.
Jim G
Old Jul 28, 2013 | 05:34 PM
vetteOnTheRun
I'm not really "stuck" on get the 3.75. A friend just put a bug in my ear. I have always thought that the 3.54 was a great gear. The more that I am hearing it seems that the 3.75 may be more problems than its worth.
Old Jul 28, 2013 | 05:42 PM
JMelton's Avatar
JMelton
If it ain't broke, don't fix it.........
Old Jul 28, 2013 | 05:48 PM
84wannabezo6's Avatar
84wannabezo6
I was talked out of the 373 and into 342 ratio for my Camaro and Im happy with the compromise. I think the 373 is gonna be winding pretty high on the highway especially if you go 75-80.
Old Jul 28, 2013 | 05:52 PM
JimGnitecki
3.73 > 2800 rpm at 80 mph
3.54 > 2667 rpm at 80 mph
3.42 > 2576 rpm at 80 mph
Not much difference really, especially for a 5900 rpm engine.
Jim G
Old Jul 28, 2013 | 08:19 PM
Rob31's Avatar
Rob31
I have a good carrier for sale that has a 3:73 on it . Dana 36
no pinion though
Old Jul 28, 2013 | 08:21 PM
JimGnitecki
no pinion though
Don't rings and pinions need to be "matched" to each other for life )as well as properly installed and shimmed) in order to not be noisy?
Jim G
Old Jul 28, 2013 | 08:34 PM
Rob31's Avatar
Rob31
Like I said , I have a good carrier ,clutch pack . that will fit a 3:73 in a D-36 .
50.00
Car was parted out . carrier was left behind
Old Jul 29, 2013 | 08:47 AM
rklessdriver's Avatar
rklessdriver
WVZR-1 has a complete brand new 3.73 D36 for $750 in the classifieds...
http://forums.corvetteforum.com/c4-p...and-seals.html
Once you buy a gear set, new brgs, new seals, set up shims, new posi clutches and pay someone (who knows what they are doing) to set it up, your gonna be more than $750 into it.
Will
Old Jul 29, 2013 | 09:10 AM
JimGnitecki
Will
You're going to be more than the $750 into it if you have to PAY a SHOP to swap out your old D36 and put in WVZR-1s, though! PLUS, you have to pay the cost of shippnig the housing to you, which is not cheap, since I think you need to go truck freight, not UPS.
My total swap including the cost of the new Richmond Gear ring and pinion set, plus install kit, plus synthetic lubricant, plus LS fluid, plus shop labor will, according to the shop, hit about $1050 to $1150 (their well experienced specialist does it in 6 hours labor and insists on very precise clearances), and that's the best hot rod and custom shop in town.
So, unless the OP can find a shop to provide all labor plus syntehtic gearoil and LS fluid for $300 to $400, he'll spend more doing the complete rear housing swap, at least until he can sell the old D36, and then have to try to sell that D36 with 2.59 gears locally, since shipping it would cost a used buyer a lot . . .
Plus, it's a heck of a lot more complicated set of transactions in total.
You have to consider the WHOLE picture.
Jim G
Old Jul 29, 2013 | 10:11 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I wish I would have put in 3:73,s now that mine is becoming a dedicated autox car. But the 3:07 gears I put in worked great for the street. If you buy a pumpkin from someone figure around $80 for shipping which is not too bad.
Old Jul 29, 2013 | 10:36 AM
383vett's Avatar
383vett
When my car was a street/strip car, I ran a 3.73 rear gear with an auto and was very happy with it.
Old Jul 29, 2013 | 10:41 AM
JimGnitecki
Yes, for drag strip use , the 3.73 is pretty decent with an auto, if the engine is stock. You are at about 5300 rpm in 3rd at the 1/4 mile marker.
The 3.54 has you at about 50oo to 5100 rpm at the 1/4 mile.
The above are both with stock size tires. With non-stock tires, the rpm may of course be different.
Jim G
Old Jul 29, 2013 | 03:10 PM
WVZR-1's Avatar
WVZR-1
The rear is easily shipped either UPS or FEDEX - there's NO freight company that needs involved. I believe the OP is actually not that far from me and contacted me regarding a buy and I told him I had no use for his 2.59 but that I'd consider cash and a trade. He never contacted me again.
OP - if you haven't contacted me I apologize for implying that you had. Are you from Hagerstown?
To Gear upgrade
Old May 26, 2015 | 02:57 PM
snovette's Avatar
snovette
3rd Gear
Do the swap. Its worth the cost. If you can't spend a grand on your car. Why do you have it? Its a hobby and that costs money. Change over to the Dana 44 while your at it. Much stronger posi unit. I would recomend staying wkth the 3.54 gear or below if you plan on any extended hwy driving. Iwent with a 3.23 gear and it is great.
Old May 26, 2015 | 03:49 PM
Silver96ce's Avatar
Silver96ce
You're reviving a dead thread. Nearly two years old. I hope he made a decision way before this.
Old May 26, 2015 | 10:32 PM
Zrxmax's Avatar
Zrxmax
You might want to consider 3.07s. The same ratio as the G92 option in your car. It definately wakes the car up. You should be able to find one intact with decent miles for less than your going to spend.
