ESC wire sorry
Old Aug 15, 2013 | 10:29 AM
jseremba's Avatar
jseremba
Default ESC wire sorry
hello
I have a 1984 4plus3 stock corvette.
I was checking my timing and disconnected what I thought was the Electronic Spark Control wire. When I disconnected the wire the Tach went shut off and the CEL did not come on. Did I disconnect the wrong wire. The wire I disconnected is yellow or white and goes through a filter or condensor.
If I did disconnect the correct wire, why did the CEL not come on?
Thank you,
Joe
and if you know how to post a picture please tell me.
Old Aug 15, 2013 | 12:10 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like you disconnected the tach filter, thus no tach.
The EST wire on my 86 is beside brake booster and if I recall, it is tan in color.
Old Aug 15, 2013 | 12:13 PM
jseremba's Avatar
jseremba
Default esc wire
I think you are correct. Thank you
Old Aug 15, 2013 | 04:54 PM
nutz4c4's Avatar
nutz4c4
.. between the brake booster and the wiper motor. Tan/brown with a black stripe
Old Aug 15, 2013 | 04:59 PM
aDigitalPhantom's Avatar
aDigitalPhantom
but being the computer person I am, I thought this was about wiring an Escape key for some reason.
Old Aug 15, 2013 | 10:58 PM
jseremba's Avatar
jseremba
Thank you. I cannot understand why the CEL is not going on.
Have you ever tested the vacuum of your Corvette. Mine is pulling 16 inches of vacuum aty idle
Old Aug 16, 2013 | 05:03 AM
Cliff Harris's Avatar
Cliff Harris
Lets go nuts with acronyms... ;-)
ECM is Electronic Control Module -- also sometimes called Engine Control Module. Later cars have PCMs (Powertrain Control Module) -- same thing, different name.
ESC is Electronic Spark Control -- that's the spark timing retarding done by the ECM in response to signals from the knock sensor and knock sensor module (called ESC module).
EST is Electronic Spark Timing -- that's the spark timing that the ECM adjusts to match the engine operating conditions.
The tach signal from the distributor is connected to the dashboard. The ECM uses pulses from the ICM (Ignition Control Module) in the distributor to determine RPM. It's a completely separate signal.
Old Aug 16, 2013 | 05:23 AM
nutz4c4's Avatar
nutz4c4
While my car is far from stock it pulls 17" vaccum
Old Aug 16, 2013 | 07:07 AM
jseremba's Avatar
jseremba
okay I guess what I am asking is does anyone know how many inches of vacuum the stock L83 should have at idle
thank you
Old Aug 16, 2013 | 11:18 AM
MrWillys's Avatar
MrWillys
20 to 22 depending on how many miles are on it if it's in good condition.
Old Aug 18, 2013 | 12:40 PM
jseremba's Avatar
jseremba
The engine has good compression. All of the cylinders had about 200 psi when I did the compression test. So I am assuming that it is in good condition. Only has 72 K on it. Just trying to figure where it can leak. Can the EGR system cause vacuum problems?
Old Aug 19, 2013 | 02:19 AM
Cliff Harris
If the EGR valve is stuck open it is a vacuum leak.
Sometimes carbon buildup in the EGR passages in the intake manifold can block the EGR valve from closing completely.
To ESC wire sorry
