Another crank, no start!
Old Nov 6, 2013 | 04:59 PM
jnorth's Avatar
jnorth
So, I changed out the ECM and it still throws all of those codes!! Not sure what to do at this point.
Old Nov 6, 2013 | 10:43 PM
vetteoz's Avatar
vetteoz
Originally Posted by jnorth
where is the ccm located?
Old Nov 6, 2013 | 10:55 PM
vetteoz's Avatar
vetteoz
Originally Posted by MrWillys
Personally, I wouldn't think the CCM would cause this issue
I say that because there are many DTC 41 threads across all the C4 forums ; guys have lost their hair trying to identify what is actually causing the problem ;ECM , CCM or the wiring
The Comms problem appears more commonly found on 92/93 ECM's
http://forums.corvetteforum.com/1554492041-post15.html
http://forums.corvetteforum.com/1575410655-post12.html
Old Nov 6, 2013 | 11:01 PM
MrWillys's Avatar
MrWillys
If Vettoz is claiming it's the CCM, I'd go with that. This way, you can blame him if it's not the solution.
Old Nov 6, 2013 | 11:38 PM
jnorth's Avatar
jnorth
Haha! Will do.
Old Nov 9, 2013 | 09:38 AM
jnorth's Avatar
jnorth
Well guys, would you believe that it was just the key? I got a new key, plugged the starter enable relay back in and she fired right up! After sitting for 2 years!! Thanks for your help with this. I believe I still have some codes to work through.
Old Nov 9, 2013 | 12:02 PM
Giamanut's Avatar
Giamanut
What prompted you to get a new key? Awesome it running now
Congrats
Old Nov 9, 2013 | 01:16 PM
jnorth's Avatar
jnorth
Well, I figured it would be dumb not to try the cheap stuff first.
