Front brakes 93
Old Dec 14, 2013 | 12:22 PM
calvette 11's Avatar
calvette 11
Default Front brakes 93
I have a 93 vette. I'm not getting enough front brake pressure. It is not enough for the line lock or regular brakes doing panic type stops.
I have bleed the brake system several times changed pads and replace the booster. This car has never had a good pedal and I have owned this car eight years. Is there something I can do?
Old Dec 14, 2013 | 02:34 PM
charliet615's Avatar
charliet615
Have you considered that the front brake lines may have collapsed?
Old Dec 15, 2013 | 05:55 PM
DUB's Avatar
DUB
Do you still have the ABS unit installed????
DUB
Old Dec 24, 2013 | 10:21 AM
pcolt94's Avatar
pcolt94
You are making an assumption based on no data which is you opinion. Unless you measure the brake pressure with a gauge which measures in the thousands of psi, then you really don’t know.
Chances of 2 bad flex lines at same time is nearly impossible. Car would pull or brakes would not release.
Many C4 cars have poor brakes. I ended up putting the 13" J55 brakes on mine which made a big difference (after replacing almost everything including the ABS). It was not until a few years later that my booster went bad and leaked. After the routine replacement the brakes were really great. The original booster had no defective symptoms but the new one worked much better. Don’t ask for I can't explain that but was happy with the outcome.
Old Jan 5, 2014 | 07:15 AM
calvette 11
Default brakes
DUB
Yes the ABS works
Old Jan 5, 2014 | 07:21 AM
calvette 11
Default brakes
I have replaced the booster and master cylinder. A few years ago the lines collapsed on the front of my c-3 and I lost front brake pressure.
The front lines have never been replaced. I will give it a try and replace them.
To Front brakes 93
