Adding wire to battery?
Old Dec 22, 2013 | 11:54 AM
95wht6spd's Avatar
95wht6spd
Default Adding wire to battery?
What are you guys doing to add additional power wires?
I really hate the design on this, big molded rubber piece, with short bolt that can't be removed easily, and virtually no cable slack!
I can barely get 1 o ring connector on, I need to add two more wires.
These are for headlights, have them into 60 amp light fuse for now.
Was thinking of just taking a short heavy gauge wire w o rings on both end, one to battery, the other end w a bolt and nut that I can just clamp all three o rings together with, a dongle I guess.
Old Dec 22, 2013 | 12:19 PM
Klyde's Avatar
Klyde
I have seen battery bolt replacements that have additional connection threads on the outward side. They are tight but fit. Best I could come up with when adding to my 89' many years ago. I also added an automotive fuse block with several connections and used this to feed it. When it comes to something as important as headlights you want to do it right. They are available at many locations. Or you could order these. If you order these I would go to Lowes and get a brass nut to go with them. Bi metals don't play well with each other.
http://www.ebay.com/itm/Wirthco-2-Pack-Battery-Bolt-For-Side-Mount-Terminal-Batteries-Long-Stud-/151027372769?pt=US_Power_Tools_Batteries_Chargers&hash=item2329eed2e1
Old Dec 22, 2013 | 01:30 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
This is what I bought the other day and am currently using on my 89' Corvette.
http://www.sonicelectronix.com/item_...-SPT55308.html
Hope that helps and it is a good price and good quality.
Old Dec 22, 2013 | 01:31 PM
black88z51's Avatar
black88z51
I bought a new pos cable it has one smaller red coming out that has connections for 3. I think to hard wire to those for reliability. Have you thought of getting a battery with both top and side posts? Maybe connect to the top of that?
Old Dec 22, 2013 | 02:55 PM
383vett's Avatar
383vett
I've swapped the battery terminal bolt for a header bolt and cut a slot in the plastic insulator so additional ring terminals will fit flat between the terminal end and the battery.
Old Dec 22, 2013 | 02:59 PM
UNCLEBILL's Avatar
UNCLEBILL
Wirthco 2 Pack Battery Bolt for Side Mount Terminal Batteries Long Stud | eBay
That's what I have on my battery for my extra connections. Great add on.
Bill
Old Dec 22, 2013 | 03:01 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
I'd like to see a picture of what you are talking about, for some reason I just can't picture it.
Old Dec 22, 2013 | 04:18 PM
383vett's Avatar
383vett
You're 4 years too late. The battery is now inside the rear bumper and I have a terminal block where the battery used to be. A battery bolt is a 3/8" bolt, the same thread and pitch as a header bolt. The header bolt will get you more length to add ring terminals.
Old Dec 22, 2013 | 05:11 PM
95wht6spd's Avatar
95wht6spd
I did trim rubber off the positive cable some. I did see these longer terminal bolts ha is what I thought of first, but How did you get bolt out? Seems there is a metal bracket inside rubber that retains bolt.
Old Dec 22, 2013 | 06:27 PM
DUB's Avatar
DUB
I do not use those type of battery bolts. I do not like the ones with a threaded end. It often times becomes very constrictive on a C4 positive battery cable area.
I prefer to go to a car stereo house and get the ones where there is a bolt that goes in the end of the new terminal bolt. Much shorter than what was previously posed in a photo. I use them quite often and there is no need to cut any material at the battery terminal cable end.
I get mine through Freeman's Car Stereo here in Charlotte NC. I believe they are made by "stinger" if my memory serves me correctly.
DUB
Old Dec 22, 2013 | 06:51 PM
Klyde's Avatar
Klyde
DUB:
That is what Red89' posted a link to. Either way you can remove/disconnect your extra connection without losing all your settings. (radio, A/C)
95wht6spd: How did you get bolt out?
I just pushed the bolt with my thumb while turning it and it came right out.
Old Dec 22, 2013 | 08:51 PM
95wht6spd's Avatar
95wht6spd
The Stinger, so you plug this into the battery, then you screw the old cable into the stinger?
Old Dec 22, 2013 | 11:41 PM
wilcar's Avatar
wilcar
I run an 8 gauge wire from the hot post on the back of my alternator to a relay to power my fuel pump circuit and an aux fuse block. You should be able to get two ring terminals on the alternator post.
Old Dec 23, 2013 | 01:42 AM
Churchkey's Avatar
Churchkey
There is a 12V (always hot 12V) junction block behind the battery that the fuse link wires connect to. Its a stud with a hex nut, suggest connecting the extra leads to it = no fuss, no muss, nothing to buy or deal with when servicing the battery.
Old Dec 23, 2013 | 09:06 AM
Klyde's Avatar
Klyde
95wht6spd: The Stinger, so you plug this into the battery, then you screw the old cable into the stinger?
No. You remove the original bolt from the original cable. You then screw the Stinger into the battery through the cable like the original stud/bolt and then there is a smaller bolt that screws into the Stinger that you can add additional cables to. Instead of a threaded stud like my suggestion it is a bolt that is drilled and threaded inside. It gives you a little more room/clearance. The downside is since it is a larger bolt with a smaller bolt screwed into it, it excepts a smaller wire then the one I suggested. Headlights draw up to 60 amps so I thought the threaded stud type was in order but you might get away with the smaller Stinger style ones.
Old Dec 23, 2013 | 06:29 PM
95wht6spd's Avatar
95wht6spd
Never noticed this, I take it battery removal is required?
Old Dec 23, 2013 | 06:52 PM
DUB's Avatar
DUB
95wht6spd: The downside is since it is a larger bolt with a smaller bolt screwed into it, it excepts a smaller wire then the one I suggested. Headlights draw up to 60 amps so I thought the threaded stud type was in order but you might get away with the smaller Stinger style ones.
Your thoughts are correct...in theory...except for the fact that the alternator stud on the back of the alternator is smaller then the bolt on the Stinger battery end...or darn near the same. And the stud at the back of the alternator has a surface area less than the eyelet in the wire...so there is terminal overhang....unlike the battery cable terminals.
I DO LIKE and use the studded terminal bolts like what you posted....when they do not become an issue for clearance and or servicing. I do prefer sliding an eyelet terminal on a stud instead of putting the eyelet on a the bolt and installing it. But ..like a always say..."it is what it is" and sometimes I have to deal with "stuff" that i have to deal with.
From what I often find when I am repairing wiring changes from people who just crimp on whatever they find at the parts house is that if the wire is drawing a high amps...the eyelet needs to be significant..in diameter, surface area and also thickness.
DUB
To Adding wire to battery?
Old Dec 23, 2013 | 07:02 PM
DUB's Avatar
DUB
If you car has this 12 volt junction block area. JUST BE CAREFUL...if you are planning on adding wires to it that are quite significant in gauge. If you are going to add two 10 gauge wires to this junction block to feed power to you headlights...I would think again. the reason being is that the supply wire going to it from your positive battery cable is a specific gauge ( lets say 8 gauge...because I am not at work and do not have a service manual in from of me)...by adding extra wiring to this terminal junction block ...you can overload it and eh supply wire can fail due to a high amp draw being much higher than it was intended to supply power to.
When I am adding wires to a junction block I figure out if the supply wire has to be increased in gauge to be able to handle the higher amp draw that I am attempting to supply to a new component.
I know GM built in a "cushion" for safety....and they did figure that all wires coming from this junction block...if needing power at the same time...the supply wire could supply it safely....and this area would not get hot.
DUB
Old Dec 23, 2013 | 07:17 PM
hooked073's Avatar
hooked073
Personally i do not like cutting thew insulation from the Term, That is a GM pat and one of the best the have ever had.It prevents air moister and crud from getting around the connector this preventing corrision for the most part. If you get corrision on a GM term they are eith not tight or they are cut. Also make sure what ever you hook up the alt hass enough as? to carry it. Also make usre that you have a fuse or a breaker build into the system
Old Dec 23, 2013 | 10:01 PM
95wht6spd's Avatar
95wht6spd
I am not using the alt, I am removing them from alt. check out my other post on haedlight bulbs if interested In details.
