interior light timer
Old Jan 3, 2014 | 01:07 PM
Grenkepr's Avatar
Grenkepr
Default interior light timer
'88 auto. My interior lights would not shut off after closing the door and removing the key. I pulled the fuse but that also controls the heater, hence no heat. I replaced the fuse and took out the interior light control timer, which solved the problem, just had no interior lights. However, the next day my battery was dead. Apparently the circuit stays open allowing the battery to drain. Is there a way to wire the timer plug to close the circuit or possibly get into the timer itself and rewire. Having trouble finding a replacement timer, so maybe there is a way to fix this problem until I do find one. Thanks !
Old Jan 3, 2014 | 01:20 PM
pcolt94's Avatar
pcolt94
I would start out checking the door and hatch switches.
The door switches (most common) may not be working correctly and may need an adjustment.
Old Jan 3, 2014 | 01:24 PM
WW7's Avatar
WW7
A few days ago one of the guys on here said he wired the interior lights to go off when the door was closed without having a timer, so it can be done..Hopefully he will chime in and let you know how this was done..WW
PS...I just went on ebay and found 3 used and 1 new interior light timers....Just type in (88 Corvette interior light timer) to get the listing....WW
Old Jan 3, 2014 | 01:45 PM
Grenkepr's Avatar
Grenkepr
Duh ! Ebay, I've been to all the used corvette places with no luck. Thanks..........
Old Jan 3, 2014 | 01:46 PM
Grenkepr's Avatar
Grenkepr
Did that. They work, but thanks.
Old Jan 3, 2014 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If the timer is done and your not worried about the timer, splice all 3 white wires together and lights will work only when door is open.
Old Jan 4, 2014 | 01:07 AM
Cliff Harris's Avatar
Cliff Harris
Willcox makes replacement timers, both with and without the delay.
http://willcoxcorvette.com/advanced_...keywords=timer
Old Jan 4, 2014 | 11:18 AM
Grenkepr's Avatar
Grenkepr
Thanks Agent 86.........you've helped me many a times.
Old Mar 9, 2014 | 12:41 PM
jimfvandyke's Avatar
jimfvandyke
4th Gear
I have a lights always on problem in my 90 C4. Where is the timer relay located?
Old Mar 9, 2014 | 05:15 PM
jimfvandyke
4th Gear
Thanks, I will check when I find the timer.
DOES ANYONE KNOW WHERE THE TIMER IS IN A 1990 C4?
Thanks Jim
Old Mar 9, 2014 | 05:35 PM
cohocarl's Avatar
cohocarl
How about for an '85?
Old Mar 9, 2014 | 07:01 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
84-89 Timer.
Old Mar 12, 2014 | 09:17 AM
dmghouse's Avatar
dmghouse
6th Gear
A similar problem. I have been chasing this one on my '95 convertible. Been through all the threads and changed door switches for both new and used replacements without luck, so I hope the delay timer may be involved. The radio is sometimes locked off. Interior lights come on when the doors open, security light functions normally. The radio will sometimes not come on and the clock is frozen. If a longer drive, the clock will change and the radio works. Other times the radio is fine, yet others it never comes on no matter how long the drive. Could this be a symptom of a bad timer? Could I test it by splicing wires to bypass it.? Thanks!
Old Mar 12, 2014 | 10:57 AM
milsurpman's Avatar
milsurpman
And replacement boards for the timers for half the price. Why hack it when you can fix it.
Old Mar 12, 2014 | 07:32 PM
dmghouse's Avatar
dmghouse
6th Gear
Agreed, and I will happily buy a new board if that is the problem. I just need to know if the symptoms I am describing point to a bad board. Thanks!
Old Mar 12, 2014 | 07:53 PM
samsonb's Avatar
samsonb
Will the interior lights still work if you have the door shut and turn them on?
Old Mar 12, 2014 | 09:05 PM
AGENT 86's Avatar
AGENT 86
Yes
To interior light timer
Old Mar 12, 2014 | 09:29 PM
0Willcox Corvette
Former Vendor
As a reminder to all... the boards are not a fix all for an existing issue too. The coupes seem to have an issue with the rear hatch rectifier going bad. When this happens the energy from the hatch release can zap the board. The best evidence of this is an old board that has melted the plastic housing.
Willcox
Old Mar 12, 2014 | 10:35 PM
samsonb's Avatar
samsonb
Yes
Do you leave the board connected up and connect the 3 white wires together? Or do you disconnect the board, and then connect the 3 white wires?
Old Mar 13, 2014 | 09:34 AM
0Willcox Corvette
Former Vendor
if you are doing a hard wire, you remove the old board.
