MAF Screen removed
Old May 15, 2014 | 02:53 PM
WDYWFL's Avatar
WDYWFL
Default MAF Screen removed
Last year I removed the screen in the MAF on my 96 Collector Edition with the GS engine. Immediately I noticed more power at acceleration and at idle it was noticeably smoother. To date there have been no problems. My question to all is has anyone else tried this?
Unrelated is all the questions posted with issues owners are having with their cars. After I purchased mine the next purchase were the Helm Manuals on the engine and body. Without the information contained in those books I would never attempt to dive into anything as the consequences can be expensive.
Old May 16, 2014 | 11:41 AM
JOES94LT1's Avatar
JOES94LT1
I also removed my screen and added a Throttle Body Air Foil, K&N air filter, opened up the stock filter cover to flow more air and front and rear power coupler. I can actully here the air flowing and throttle response is great.
Old May 16, 2014 | 11:51 AM
cv67's Avatar
cv67
St. Jude Donor '05
PO did that to an 89 I had
Wound up going lean intermittently and eventually blowing the head gasket. Car always felt fine but wasnt til I tried dynoing it and saw the A/F ration figured it out.
Id never do it again
Old May 16, 2014 | 01:28 PM
WW7's Avatar
WW7
Wow, the MAF for my 89 didn't come with screens.....It sure moves some big air though.....WW
Old May 16, 2014 | 01:47 PM
bjankuski's Avatar
bjankuski
Is that the blowerworks MAF sensor or a Ford slot MAF in a custom housing that you built?
Old May 16, 2014 | 02:01 PM
tunedport85inject's Avatar
tunedport85inject
it's an old trick, back in the 80's Corvette Challenge cars used it.
You can gain up to 100 cfm in air flow with screens deleted,obviously the thin wire inside the MAF is exposed to the risk of brekage.I think if the Maf is factory "tuned" to return back a voltage vs x airflow,if you add +100cfm to the max voltage you have an unexpected amount of air into the air fuel mix .Does the ECM work on the injectors pulse width to compensate for a lean condition?
Old May 16, 2014 | 02:27 PM
Lloyd Smale's Avatar
Lloyd Smale
back in the day i ran both of the irocs i had a 350 and a 305 with the screens gone and the heat sink ground down and didnt have a bit of trouble with them.
Old May 16, 2014 | 02:44 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Maybe it's time to resurrect this thread.....
http://forums.corvetteforum.com/c4-t...?highlight=MAF
Old May 16, 2014 | 03:24 PM
tunedport85inject
great thread Gregg.Some Bosch MAFs have plastic fins 3x3 mm (depend on maf diameter)coupled w metal screens.We can say that the flow into the MAF bore is playing a big role.W/O screens you have an irregular flow since the noisy signal...noisy signal = bad TB response.
plastic fins basically straighten the flow into the bore and the thin screens make it uniform
Old May 16, 2014 | 04:32 PM
blackozvet's Avatar
blackozvet
The research by superl98 is very interesting, dont you just love it when someone else does all the homework for you !
im tempted to put a screen back on the front of my maf just to see what happens.
At the end of the day tho it depends on what sort of driving you are doing, a screened maf is going to be good for street driving, but anyone who tracks their car will give up some smooth off idle control for that 25% more air flow, especially if their air intake is modified.
what we need now is someone who tracks their car to do back to back runs, with and without a front screen to see if there is any real world difference ?
Old May 16, 2014 | 04:48 PM
tunedport85inject
When you track your car you'r basically always at WOT,WOT means open loop,open loop means steady routines, what matter if you have screens or not? AFR is steady at WOT,do i miss something?
Old May 16, 2014 | 04:57 PM
blackozvet's Avatar
blackozvet
im referring to autocross, hillclimb, or circuit type racing where your off the throttle at corner (or apex) then back on the throttle, and having to squeeze it out on some corners before you get WOT,
it would be interesting to have a back to back comparison under those circumstances ?
if you were drag racing it would be better off with no screens.
Old May 16, 2014 | 05:26 PM
bjankuski's Avatar
bjankuski
I road race my Firebird with a 406 and the MAF is descreened, I have had no issues with this set-up. My data logs on airflow look good, so at least in my set-up the descreened MAF stays linear and smooth.
Old May 17, 2014 | 06:38 AM
WW7's Avatar
WW7
It's the blowerworks model, Greg Carroll "the owner" was a great help in getting it hooked up to use in my 89...A new stock Bosch unit is $735.00, it only cost me $75.00 to replace the MAF stick in mine if it ever goes bad........Tequilaboy "Pat Cardy" did the insert of the bin files into my tune for me.. This MAF unit is awesome,car runs and idles perfectly, plus unlike the stock unit it's pretty much unbreakable.. You can throw it on the ground and kick it around and it will still work, no flimsy wire to break............WW
Old May 17, 2014 | 09:33 AM
tunedport85inject
does this "new" design work as digital or analog?I remember late Maf unit have a digital output vs early analog.Any infos about it guys ?
Old May 17, 2014 | 09:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
WW7
After buying a stock replacement MAF with screens my times picked up as it wasnt going dead lean upstairs anymore.
I think that whole de screen bit was a hack move by some tuner (hmm) back in the80s that didnt do their homework.
Old May 18, 2014 | 02:11 AM
GREGGPENN's Avatar
GREGGPENN
Neither one of your Vettes were significantly modified...or tuned for the de-screened MAF. As such, it's not a surprise you ran better with the tune that matched your stock setup.
Mine 383 is tuned for my descreened MAF. I wouldn't expect a bump in performance by adding screens. Also, my idle/off-idle throttle response is off-the-charts. Of course, that's aided by a mechanically advanced cam -- but it also doesn't seem to be "hurt" with the descreening either.
When I look at the videos of the two options, it's not even clear what we are looking at. Personally, I think the pink represents turbulence. Without a screen their is less turbulence as the air flows thru. Doesn't tell us anything else, right?
I'd be reluctant to categorize the people who figure out bins and measure components -- to improve performance as "hacks". Yes...some proceed w/o enough thought. Others, provide the rest of us with valuable information. This thread would be an example.
Experimentation is good. Thinking outside the box is too....
Try this one...Why isn't WWF's oversize MAF screened -- if the screen is SO important?
To MAF Screen removed
Old May 18, 2014 | 11:17 AM
856SPEED's Avatar
856SPEED
Well said..........
Yes and for that matter, any of the newer platforms do not utilize screens, my brothers' 03 Cobra, utilizes a very large screenless MAF, and I believe the newer generation platforms, LSX.....do not utilize the screens either.....I would tend to believe this was something early in the electronic multiport fuel injection days GM utilized to overthink of keeping the wires and other elements in MAF's safe. The guys at TPIS not only take out the screens but also file down the other elements in there, although ALOT of care must be taken when performing that task.
Old May 18, 2014 | 12:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
I could be missing something but to remove the screen and tune to do what a screeened MAF is supposed to do in the first place?????
Old May 19, 2014 | 12:42 AM
GREGGPENN's Avatar
GREGGPENN
Understandable....but:
http://www.gmtuners.com/pda/flow.htm
Anyone considering a bump to a 52/58mm SHOULD be looking at their MAF and/or air box first.
I find it surprising that the OP saw a bump -- of the car is stock.
Two different trains of thought....modifying for more power versus descreening for stock improvement. I would consider (guess) the later fairly fruitless.
