Thanks for the info.
It is an L98, which is the previous gen to the LT1. I noticed you said "LTx", so does that matter?
For someone with fairly limited mechanical expertise (I've bled brakes, replaced a starter, changed spark plugs, etc, but nothing major), how many hours of work would you estimate that to be? I assume changing bearings requires pulling the engine?
Oh, sorry, for some reason I was thinking it was an LT1. I digress.
