Change Bearings by Dropping Pan?
If this holds me over until the rebuild, great. If not, it's a learning experience.
And you'd be amazed at the difference punctuation makes.
I'm just a little frustrated that one second you tell me I can't do it, then when I go slowly to make sure I don't screw up you tell me I'm going too slow, then you tell me again that I am not putting enough time into it.
I wasn't making fun of you any more than you were making fun of me by giving me advice. Fact is, it's difficult for me to read without proper punctuation and I know others have the same difficulty.
On the topic of respect, telling someone to "go ----- theirself" doesn't rank very high.
And I assure you, I'm not a punk. Nor do I ask for what I can't earn. I do yard work for my neighbors for minimum wage (or less) and have been studying non-stop to get good grades so I can become an engineer.
I respect people like you that make their way with nothing but hard work - people like that are what make America great.
Mal-lack-ka Tha-gest-tees Te-con-ess Ka-thou-low Hee-sa Aaa-coo-moo-os Me-cross
I'm not taking a shot at you because you're different by any means. How would I even know you're "different"?
Why do you have such a big chip on your shoulder?
Thanks again for all of the time you guys took to give me advice!
I am enjoying this thread, and have gotten a few tips, and enjoy seeing an enthusiastic young man tackling a new project. I hate it when threads go South because someone changes the subject or gets hurt feelings.
I appreciate any and all help this forum provides, as there are a lot of smart, experienced car crafters to glean info from.
Please post and let us know how it's going
I buy a single "standard bearing" and I buy a single ".001" oversize bearing (which means the bearing is slightly thicker to accommodate wear on the crank)
I then install and check each bearing journal with both the stnd and .001 os bearings and check the clearances with plastigage; chances are some journals will be okay with the standard bearings, but some others will need the oversize bearings; keep track of which journals take the standard bearings and which take the oversize bearings and order accordingly; Summit sells individual bearings,
After market bearings are so much simpler because they are clearly marked "stnd" or ".001 OS"; unfortunately the factory uses a letter code; ".0006" (probably .0005) indicates a bearing one half thousandth oversize, available at the factory but not so easy to find in the after market.
good luck
LeesVette suggested to flush the engine, and I think it would benefit from it, as sludge no doubt has accumulated in the engine to some degree. It might also be keeping the gauge from reporting accurately.
Now that the engine will have fresh bearings, it was mentioned that the particles might add wear to the new bearings and existing cam bearings. If flushed, wouldn't the oil filter catch the particles and keep them from getting into the engine?
Question being should he still flush out the engine after he puts the bearings in?
Just curious as to what factors are at play if you flush an engine, and I do not want to misdirect the thread but I keep wondering.....
Modern oils do an excellent job of keeping things clean – be it synthetics or dino.
There is some RTV on the pan mating surface –so perhaps someone has been in there before?
As before – just my observations – others will differ –
Jake -
Having said all of this, with the amount of visible metal on the old oil, I'd have checked every rod bearing before wasting time mail ordering parts. Although number one is the most logical bearing to fail due to oil starvation, I have seen other rods fail. If the rods and mains are good, then the cam bearings are highly suspect. Not knowing the history on the motor, it is hard to speculate on what could have caused a cam bearing problem. Maybe stiffer valve springs and an agressive cam grind by a previous owner? Hard to say, but it seems like when cam bearings wear at a normal rate, varnish fills in the resulting void on the upper half of the bearing, so guessing the failure path is anyone's guess if the lower end checks out OK. I'd even inspect the cylinder bores and piston skirts from below for signs of damage. A connecting rod doesn't have to be bent much to wear a piston skirt and/or stress a rod bearing to the point of shedding metal. I hate to sould like all doom and gloom, but unless you spot clear evidence of metal on metal wear, an oil pump and new inserts is unlikily to solve anything. That metal came from somewhere...
I know you have already ordered parts, (I just stumbled across this thread today) but you will need an oil pump driveshaft that has a metal sleeve on the pump end. The standard shaft has a plastic sleeve that usually crumbles over time, or breaks when you remove the pump.
Good luck and keep us posted.
Jake -
good luck
I wish I could tell you. I bought the car on non-op to fix it up from someone not very technically-minded who wasn't the original owner so I'm a little spotty on the vehicle history.
I wouldn't be surprised if the pan had been dropped before - the previous owner had a lot of work done to it.
There was a problem with gas washing the cylinders that could have caused wear there though.
The metal stayed in suspension for a long time and was nonmagnetic leading me to believe it was solely bearing material. And I appreciate any realistic point of view, doom and gloom or not.
Thanks, will do! And thanks again for the info!
Yep, it has the ZF 6-speed.
So, what does the wear on the thrust face mean for me?
Guilty. I wiped it off with a shop towel before I plastigaged. Thanks for the tip; I'll clean it off.
1. Replace rod bearings, one at a time.
- Remove old cap.
- Replace bearing in cap.
- Plastigage bearing to make sure clearance is okay.
- Grease the bearing? Not sure what to use for this.
- Reinstall cap.
- Repeat for each rod bearing cap.
2. Replace main bearings, also one at a time.
- Remove cap.
- Roll out upper half of bearing.
- Grease new upper half and roll it in.
- Grease the bearing (again, not sure about this one).
- Reinstall cap.
- Repeat for each main bearing cap.
3. Replace oil pump: I'm looking for anything I'd need to do besides swapping the pickup to the new pump and slapping it in. I've heard reference to a need to bend the pickup tube because of the larger size of the HV pump or a need to weld the tube to the pump?
