Backfired and stopped running
1) seems your dizzy was off at the end,i adviced you to ceck this before any attempt to put new parts and efforts over this car (timing chain i.e)
2) throwing parts never pay untill you are a "stealership" they did it as job....
But if i remember, you were in need of a new WP, so changin' a timing chain, in an old engine, is still good .
All your efforts in changing parts made grovin' your frustration,but now engine problem is solved and it was a stupid oversight about a common mistake,the dizzy,as you said ,was simply off.
Now, onto the service belt,may be you put it the wrong way in,or it was not well aligned onto the belt pulleys threads and it simply slipped out, and was chewed.Belive me most of us ,at least one time,were near to set the baby on fire,or hammerin'it to death....but ,take a breath ,let it sit for some days,then turn back put in a new belt,be sure it is routed ,tensioned and well aligned ...and you'r in business she's on the road again...problem solved...
