Code 36 help
Old Feb 6, 2015 | 11:16 PM
  #81
AJ123's Avatar
AJ123
Originally Posted by puzzigully
hmmmmmm
partially answering my own question...
The Fuel Pump relay only stays on approx for 1 sec after the ignition is turned off......
any clues as to what parameter I should be looking at to confirm ECM is actually seeing them and staying on for the required time..
I need to confirm what Cliff said:
The ECM waits 5 seconds after ignition-off to start the MAF burnoff. The burnoff lasts 1 second. The ECM shuts down 11.3 seconds after ignition-off. The burnoff test starts 0.3 seconds after burnoff starts. The ECM make 6 voltage measurements and all 6 must be within the voltage window to pass the error code 36 test.
Well on that point as John was closing the shop he decided to check the fuel pump relay. Mine was badly corrode The red wire was a little less then a 1/2 inch out of its plug. May have been touching other wires. Next week when he gets back from the beach he will repair it. I didn't think about the tests. Wish I could tell him.
Monday I will be having angioplasty and out of it. I hope I can pass your info on.
Old Feb 6, 2015 | 11:58 PM
  #82
AJ123's Avatar
AJ123
Where did you find
the info on the codes and the ECM parameters test.. What are the other five. I probably know the answer but doubt myself.
Thanks Steve
Old Feb 9, 2015 | 05:59 AM
  #83
Cliff Harris's Avatar
Cliff Harris
Originally Posted by AJ123
Where did you find
Thanks Steve
It's in the program code in the ECM:
Code:
      ;       Error 36 Params
      ;       >> MAF Burnoff diagnostics <<
LC221:  FCB      3      ; 0.3 Second delay prior to burnoff voltage test, CAL = Arg * 10
LC222:  FCB      6      ; 6 fails required to set Error 36
LC223:  FCB     95      ; Fail burnoff test if ADC > 1.90 VDC
LC224:  FCB     20      ; Fail burnoff test if ADC < 400 mVDC
Looking at this again, it looks like it could fail some of the tests and still not set an error code 36.
Old Feb 9, 2015 | 07:55 AM
  #84
AJ123's Avatar
AJ123
Code:
      ;       Error 36 Params
Looking at this again, it looks like it could fail some of the test and still not set an error code 36.
Thanks Cliff
Will pass info on to shop later today
6am I will be in for angioplasty.
Old Feb 13, 2015 | 09:02 PM
  #85
AJ123's Avatar
AJ123
Thanks Cliff
Well looks like your info helped Cliff, The voltage that was being read by the computer was 3.?. I believe John said it had to be 1.7. So the MAF sensor was the third one I have put on this project all were a1Cardone. John had autozone deliver one this morning and the ecm stop sending code 36. We also installed an 89 ecm 16198259 and an 89 prom.
I think you were right on with your voltage test thanks. John is still putting vet back together. He may finish tomorrow.
thanks
steve
Old Feb 14, 2015 | 12:17 AM
  #86
Cliff Harris
The cold start injector was eliminated in 1989 and the startup fuel calibration was changed to account for that. You might run very rich at startup, but that won't hurt anything once the engine is running.
You could disconnect the cold start injector...
Old Feb 14, 2015 | 12:32 AM
  #87
AJ123's Avatar
AJ123
sounds like you were standing there
Got rid of the 9th injector when we installed the Super Ram.
I wasn't there when they started her up but running rich at start up is what they mentioned.
Thanks again for everyone's help,
Old Feb 14, 2015 | 09:58 PM
  #88
puzzigully's Avatar
puzzigully
thanks
steve
Steve,
HOw did he measure the voltage at the ECM?
What was the problem?
Was the fix a replacement MAF?
Old Feb 14, 2015 | 10:42 PM
  #89
AJ123's Avatar
AJ123
Steve,
I think he said the green wire from the MAF plug is where the ecm received the voltage reading. He has commercial equipment that he uses to see what is taking place. I believe like I use with Datamaster but a lot better. Since I started this is the third MAF sensor that I used. He said the incorrect reading was going to the ecm.
We also replaced the ECM and prom from an 89 corvette at the same time.
Every wire and circuit has been checked or replaced.
He explained just because you see the wire glow it visually can't tell you the voltage.
When I see him Monday I will ask him exactly how he measured the voltage unless Cliff knows how it can be done. The vehicle is still at the shop he is installing a new clutch pedal safety switch. I had surgery Monday and I can't drive it yet. Still on pain meds
Old Feb 15, 2015 | 12:25 AM
  #90
puzzigully's Avatar
puzzigully
Steve,
Thanks,
Keen to know how he got a result.
I'm using datamaster to try to see the voltage, but no luck.....something screwy is going on (see above posts)
The Datamaster can't see the voltage from the maf.....just goes to 23g/sec.....don't know what dcvolts that is.....
What brand maf did you finally go with?
Old Feb 15, 2015 | 01:00 AM
  #91
AJ123's Avatar
AJ123
Steve,
Thanks,
http://<br /> <br /> Had to be one o...h&newYmme=true
Old Feb 16, 2015 | 05:58 PM
  #92
AJ123's Avatar
AJ123
By Cliff Harris this is were john found the answer. John spliced into the green wire from at the ecm. He said that you wait for closed loop turn off engine voltage should be 2 volts when signal for burn off goes through the voltage should drop to (400mVDC to 1.90VDC in your car). If the output is outside those higher or lower code 36 will occur. My MAF showed 3.4 volts John decided we try another maf sensor. The new one read 1.70VDC. For now after trying everything in the book Cliff Had the answer.
https://www.corvetteforum.com/forums...ay-issues.html
"MAF burnoff is done when the ignition is turned off. The ECM stays alive for about 10 seconds to do the MAF burnoff and to reset the IAC. The ECM must be in closed loop mode when the ignition is turned off for MAF burnoff to occur.
The MAF burnoff relay applies 12 volts to the MAF sensor wire. That causes it to glow red and burn off any deposits that may have accumulated. During the burnoff cycle the ECM looks for the MAF output voltage to be between programmed values (400mVDC to 1.90VDC in my car). If the output is outside those values then it will set error code 36.
If the burnoff relay is bad then burnoff will not happen. Over time the MAF output will deteriorate and the engine will not run properly"
Old Feb 16, 2015 | 07:20 PM
  #93
puzzigully's Avatar
puzzigully
Steve,
good to hear the measurement was successful.
How did he measure the voltage coming out of the green wire?
Did he use a voltmeter or a CRO?
By changing the MAF, it seems as though you're getting the right voltages......have you confirmed no more Code 36?
Cliff,
Do you have (or can find) the conversion chart for the MAF from g/sec to volts?
Old Feb 16, 2015 | 07:31 PM
  #94
AJ123's Avatar
AJ123
Steve,
Cliff,
Volt meter
shop is busy so when they put the new clutch safety switch in I will get her back.
I will let you know it the fix works in another week or so
Steve
Old Feb 17, 2015 | 06:57 PM
  #95
puzzigully's Avatar
puzzigully
[QUOTE=AJ123;1588977422]Volt meter
[QUOTE]
Do you know if it was a digital or analogue volt meter?
Hope you're feeling better.
Old Feb 17, 2015 | 07:27 PM
  #96
AJ123's Avatar
AJ123
[QUOTE=puzzigully;1588985634][QUOTE=AJ123;1588977422]Volt meter
I believe he used a digital
When I see him I will ask so I don't give you boas info
Old Feb 18, 2015 | 02:27 AM
  #97
Cliff Harris
Cliff,
The conversion is pretty complex because it also will work with the older MAFs that have frequency output, but here's the important stuff (in the program code there are 6 tables, but I combined them all into one for simplicity):
Code:
; gm/sec    BIN      VDC     lb/hr
;   0.0        0     0.00        0
;   3.2       64     0.18       25
;   4.5      128     0.37       35
;   6.2      192     0.55       48
;   8.4      256     0.73       65
;  10.9      320     0.91       84
;  14.0      384     1.10      108
;  17.7      448     1.28      137
;  22.3      512     1.46      172
;  22.3      512     1.46      172
;  25.0      544     1.55      193
;  27.6      576     1.65      213
;  30.6      608     1.74      236
;  33.8      640     1.83      264
;  37.1      672     1.92      287
;  40.7      704     2.01      314
;  44.5      736     2.10      343
;  47.7      768     2.19      368
;  47.7      768     2.19      368
;  51.2      800     2.29      395
;  55.1      832     2.38      425
;  59.0      864     2.47      455
;  63.2      896     2.56      488
;  67.8      928     2.65      523
;  72.3      960     2.74      558
;  77.2      992     2.83      596
;  82.0     1024     2.93      633
;  82.3     1024     2.93      635
;  87.5     1056     3.02      676
;  92.8     1088     3.11      716
;  98.6     1120     3.20      761
; 104.4     1152     3.29      806
; 110.7     1184     3.38      855
; 117.1     1216     3.47      903
; 125.0     1248     3.57      965
; 134.5     1280     3.66     1038
; 134.2     1280     3.66     1036
; 142.3     1312     3.75     1098
; 150.4     1344     3.84     1161
; 158.5     1376     3.93     1223
; 167.4     1408     4.02     1292
; 177.1     1440     4.11     1367
; 186.0     1472     4.21     1435
; 195.7     1504     4.30     1510
; 206.2     1536     4.39     1591
; 212.2     1552     4.43     1637
; 218.1     1568     4.48     1684
; 225.1     1584     4.53     1737
; 232.1     1600     4.57     1791
; 239.1     1616     4.62     1845
; 247.0     1632     4.66     1906
; 254.0     1648     4.71     1960
; 254.0     1664     4.75     1960
; 254.0     1680     4.80     1960
; 254.0     1696     4.85     1960
; 254.0     1712     4.89     1960
; 254.0     1728     4.94     1960
; 254.0     1744     4.98     1960
; 254.0     1760     5.03     1960
; 254.0     1776     5.07     1960
; 254.0     1792     5.12     1960
To Code 36 help
Old Feb 18, 2015 | 04:58 PM
  #98
puzzigully's Avatar
puzzigully
Thanks Cliff,
Going off that data, the ECM must be "seeing" around the 1.56-1.5V based on the "23" figure I'm seeing.
Still what is disturbing is the fact the Data collection does not show the MAF Burn Off "event", even though it is happening???
Steve's mechanic seemed to "see" the Burn off take place with a digital Voltmeter and get a reading...
I will have to try again to tap into the C terminal on the MAF and observe the output.
I did buy some CRC MAF cleaner and will give it a spray on the weekend and see if that works at all....
Any other advice?
Old Feb 18, 2015 | 09:45 PM
  #99
AJ123's Avatar
AJ123
Thanks Cliff,
Any other advice?
Just picked up vet. Warning. He said using an analog volt meter could burn up ECM. Make sure it is digital. He also added the reason he spliced into the green wire at the ECM was because of all the bad wiring we had been replacing. You can also check from the green wire at the MAF plug.
Good luck
Steve
Old Feb 19, 2015 | 01:27 AM
  #100
Cliff Harris
Good luck
Steve
All of the ECM's inputs are protected against over voltage, over current and reversed polarity. Using an analog meter will not damage the ECM.
I bought some decorative pins at Walmart (about 20 in the package) and used one for my MAF testing:
