Troque and Gear Ratio
Drove from Telluride, CO to Las Vegas and back -definitely not flat. I think it was in May. Full STORY HERE.
The 5 hour trip I took was 80% highway and 20% city and I got 20 mpg and that was using 4th gear on the auto. I drove with a light foot because the wife was with me, so I just do not see how I will ever get 24/25 combined. I cruised at 60 and 70 mph by the way with the AC on. And if I want to take trips like this in the future I will need to get the car quieter. Even with resonators, H-pipe in front of mufflers, and new MasterFlow mufflers it drones cruising and pops when decelerating and the wife does not like it!
I am thinking of putting a X-pipe up front in the exhaust.To make sure we are comparing apples to apples... My 94 is stock with 255/45ZR17 front and 285/40ZR17 rear.
I am by no means saying that I do not believe the two of you, but I just do not see how I get to 25/27 combined! The car may need a tune-up, but it is not running that bad.
If the car runs better at higher rpms, my first thought goes to injectors and sensor monitoring. If the 20-yr-old injectors are still installed, how well are they atomizing at the lowest throttle openings? The car MIGHT feel smooth even though it's lost a lot of efficiency? And, what's the trim doing to his mpgs?
If it hasn't already happened, swapping to new injectors, tune-up, and 02 sensor(s) is easy/cheap to do on an LT car. I'd start there before considering something illogical -- like swapping to 3:45 "sport" gearing.
Or maybe do both!
Oh yeah: I want to be sure "afgunn" realizes the two mileage examples [posted in this thread] were on a manual-equipped car. M6 refers to a 6-spd (which I also have). In a ZF-6, 6th gear has only a .5 gear ratio. 5th is also an "overdrive" on these transmissions -- coming in with a .75 ratio. That means our 5th is very close to the automatic's 4th gear. M6 transmission have TWO overdrive gears! If it were "too hard" to pull the car at even lower rpms, how/why do you think an M6 was installed AND that they get even better hwy MPG's than automatics?
C4's have VERY low drag. I've read and experienced a sweet spot in MPG's around 70mph. At that speed -- in 6th -- the motor is turning a mere 1450 rpms. The motor has the ability to do that. There is enough "torque". But, the motor has to be running correctly to take advantage of those low rpms and gearing.
30mpg is what mine got back in the early 2000's. As gasoline has migrated to higher levels of ethanol, that potential has dropped. "Gasahol" is less efficient and gets worse mileage. Because it's "cheaper", there should be a wash. Even with my converted 383 stroker, I'm still walking all over your 20mpg. Mine is still above 25mpg...at around 27. If pure gasoline were still being run in my 383, I'd probably be able to lean on 30mpg's. The extra torque of a 383 would require a bit less throttle opening compared to a 350. Again, you should have a wash.
A lot of what goes into MPG's is the weight and drag of your car. Wind and weather play a factor too. That's why individual trips make it hard to decipher results. Of course, if you're a human calculator like those guys on the new TV show, Scorpion, you could probably sift through all the variables in your head! LOL
I think gears are a fantastic mod....but they won't get you better mpg.
D44 with 3.45 was one of my first mods, it didn't help mileage however, it didn't hurt much either. Now the 23X 23X .615 lift cam did more damage to the mileage than the gears!.
One other item, maybe you guys can help. Currently the car has complete dual exhaust from the exhaust manifolds back - 3" after cats into the resonators. The original exhaust was single back to the mufflers was it not? Also, best I can tell only 2 O2 sensors are connected (1 each in front of each cat) and I believe originally there were 3 O2 sensors - one each in front of the cats and 1 after the pipes from the cats had joined into one. Right or wrong? If this has been modified from single exhaust to dual and the delete of the after O2 sensor, this would definitely affect mileage (most likely running rich) and would need to be tuned.
This and the other things you mentioned may be the reason for 20mpg.
