antennae
Old Aug 5, 2002 | 11:30 AM
Mikesa's Avatar
Mikesa
Default antennae
Don't know if this is the right forum, but the antennae on my "new" 1992 convertible, on the way home from picking it up. It wasn't going up all the way so I knew it would need relacement. The motor works fine, and when the antennae "broke", the motor pushed the "plastic" toothed section right out. I've replaced similar type masts before, not on a vet. Anyone know how I get the black piece on the top of the antenne out or do I have to take the whole antennae out to feed a new relacement mast in. Also, anyone know where I can get a preplacement mast for a 92.
Old Aug 5, 2002 | 11:36 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: antennae (Mikesa)
http://www.madvet.com/pdf/601242.pdf
I did mine a few months ago. I found it easier to remove the antenna assembly entirely as you can get it out of the vert from below with just two screws. Mid america, zip and all the others sell the replacements.
[Modified by 92TripleBlack, 10:38 AM 8/5/2002]
Old Aug 5, 2002 | 11:42 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Do a search on this topic, a Forum member did a recent post on just this item.
Old Aug 5, 2002 | 11:44 AM
Mikesa's Avatar
Mikesa
Default Re: antennae (92TripleBlack)
I just drove the car home from Louisiana to Massachusetts, drove 16 hours straight yesterday. I've requested all those catalogs, and expect them soon. When you remove the antennae unit, is there any nut on the top of the antennae at the body, or does it just slide through what appears to be a black "grommet".
Old Aug 5, 2002 | 12:46 PM
Mikesa's Avatar
Mikesa
Default Re: antennae (65Z01)
I'm kinda new, and I just found tons of info posted by different members talking about the issue, I even found user, onedef92, who indicated he posted instructions, I just can't find them. I'm hoping it's because I'm new and not stupid, but time will tell.
Old Aug 5, 2002 | 05:23 PM
Mikesa's Avatar
Mikesa
Thanks to those who responded. I got a relacement antenna, fed it down in, and everythings just fine. When it broke, the motor "spit" the antenna and nylon toothed "tail" out completely. So it took the new one with no problem.
Old Aug 5, 2002 | 06:00 PM
tbmoore's Avatar
tbmoore
I bought a new mast for my 94 and it never did work right. ended up getting the whole unit. I wasted the money I spent on the mast. would have been cheaper in the long run and less trouble to do the whole thing right off the bat.
To antennae
