86 Speed correction
Old 02-16-2015, 10:41 PM
PMARTINEZ92126
PMARTINEZ92126's Avatar
Default 86 Speed correction
Ok I researched myself into confusion. I have an 86 automatic corvette. I had the rear diff changed to 3.54 gears along with 17 inch rims with 315 tires on the rear. In doing research I was told I needed to change out the drive gear to a 15 tooth gray gear and a 41 driven gear yellow. I was told several things by different shops. FIrst thing I needed to have was the DRAC chip reprogrammed because changing out the gears wont help. Is this the same as the prom chip I sent in to get the specs changed? 2nd I was told to change out the gears only, but when I brought him the driven gear he said that the gear I needed isn't available. I just had the transmission rebuilt and have it installed partially in the drive way. I have the drive shaft out so I figured now would be a good time to try and fix it. Any ideas to how to fix this or should I just put in back in and deal with the speed being off.
Old 02-16-2015, 11:08 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Ya know the speedo calibration is based on the number of tire revolutions per mile.
So simply changing the gears on a 86 is your answer.
Most tire mfgrs have RPM info in the tire spec chart.
Search around you'll find many threads that will help decide the gears you'll need.
Old 02-16-2015, 11:11 PM
Dt86
Dt86's Avatar
Here's a chart with all of the different gears,axles and tire sizes. http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
I just had to hunt down a 42 tooth driven gear and 308 VSS. They are getting hard to find.
Old 02-17-2015, 01:19 PM
bjankuski
bjankuski's Avatar
The easiest thing to do is by an electronic speedometer calibration box for Dakota Digital (I believe it is called the SG-5), costs less then $100, wire it in program it and forget about it.
Old 02-18-2015, 05:03 PM
86C4Z51
86C4Z51's Avatar
Put a GPS in it?
Old 02-20-2015, 08:50 PM
rrt898
rrt898's Avatar
I changed my rear to a 3.54 also in my 86. I also changed both gears when I rebuilt the trans. I used this site to order my gears http://www.transmissioncenter.net/sp...n_______va.htm.
Old 02-20-2015, 09:04 PM
SouthCoaster
SouthCoaster's Avatar
Go here.
http://webpages.charter.net/khasting...peedocalc.html
It's so accurate it'll even factor in your tire squish from the weight of the car.
To 86 Speed correction
Quick Reply: 86 Speed correction
