coolant to throttlebody
If the two large inlet/outlet hoses you're referring to at the reservoir tank are the lines to and from your heater core, doubt you'll need heat to autoX!
https://www.corvetteforum.com/forums...nt-intake.html
...WW
Note to all noObs
This Forum offers a wealth of information. We are all car guys and like to help each other out. Since the newest C4 is now 19 years old almost every problem and every modification as well as every part has been solved, tried and reviewed right here and commented on.
SO: before you ask your question, please take a look around at what is being discussed currently. There may be another NoOb that has posted this same question in the last day or so.
NEXT If your question isnt recently written about, try the "SEARCH" function. Ignore the obvious stand alone "SEARCH" box and look at the red bar that runs across the top of the page. You will notice in that bar is another "SEARCH" with a drop down arrow. If you click this arrow it will bring up another "SEARCH" box. IGNORE that and look down further to the "ADVANCED SEARCH" and click that. Now you are cookin with gas. In the term box, type in some basic search topic and then, most importantly, scroll down in the forum select and choose one of the C4 specific forums or choose the main C4 header to search thru all the C4 forums. This is most important or you will be searching thru all the Corvette forum and will bring up any topic from C7, 6, 5, 4 ,3, 2, and 1 ever written with your search terms.
If this method doesnt work, try changing a few words around, shorten your terms broaden or narrow your search. Then if you dont find something that helps you out, post specific questions that will help us solve your problem.
And Please, Please, Please dont start a topic with a title "HELP! with no other words. We are gonna help but you will get more response from someone if you ask a specific question because someone who has experienced the same thing and has a solution will be more apt to answer.
RANT OVER
Note to all noObs
RANT OVER
The current noobs that will chime in give you less than a 50/50 chance of good info.
So rather than take jabs at those that could really help you.
Take their advise and use the search feature and draw on two decades of info.
A search method that narrows the results much better is known as an AND search. In that case, the results will only show posts that contain "one" AND "two" AND "three". You can do an AND search by putting "AND" (must be uppercase, no quotes) between the search terms.
I want you to follow my instructions and enter "coolant bypass" with the quotes in the search term box following the instructions I had written above. It would have saved you time (you had to type two words) that you seem so lacking for in your life.
This is just 5 of many and you will see I responded to most. , so no, I am not just sitting on the edge of my seat waiting for a poor boy like you to screw up and ask an innocent question and act all superior.
https://www.corvetteforum.com/forums...-searched.html
https://www.corvetteforum.com/forums...on-85-tpi.html
https://www.corvetteforum.com/forums...-and-smog.html
https://www.corvetteforum.com/forums...nt-bypass.html
https://www.corvetteforum.com/forums...-question.html
Yes I'm proud of you son. You are Corvette Forum man of the year. Thanks. I'm going to unsubscribe this thread before we waste any more server space on nonsense
Ive probly got underwear older (and smarter) than you. Since you would rather argue than learn anything, I think Coach is right.Do us all a favor and save a little more server space, delete your registration and head over to SmokinVette. I am sure you will be just as popular over there.
