Frame question..
Old Jun 3, 2015 | 07:18 PM
  #41
Chevrolet12's Avatar
Chevrolet12
I thought the same thing when I seen the picture after I put it up then I crawled under it again and it's not.. Must be a glare.. Or the hole that was drilled is oval.
Old Jun 3, 2015 | 07:19 PM
  #42
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by VikingTrad3r
ok, obviously im out to lunch. i am REEeeeALLY surprised though. it is astounding to me that the c beam is unnecessary edit: for anything other than holding the tailshaft side up.
That isn't the C-beam's only function. It's other function is to manage the reaction tq of the rear diff housing under acceleration and deceleration. In a modified car w/slicks, this force can be enought to lift the front wheels of the car. So the C-beam is VERY strong...in one direction. PLEASE, read THIS LINK that has been posted for you twice now, in this thread. You'll learn a lot about an important and unique part of your car.
Old Jun 3, 2015 | 07:23 PM
  #43
Chevrolet12
I just need a tip on how to make a crossmember or make my c beam work which I don't think I can now that the top bolt holes are cut off. If I can get an idea for the crossmember I will get to making one.
Old Jun 3, 2015 | 07:26 PM
  #44
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Chevrolet12
I think we are getting on the same page here. I took a picture of my mount it only bolts to the bottom lip of the c beam.. The top was cut off.. It's kinda hard to see with the exhaust in the way
How far back was the top cut back? Youre trans is moving up and down b/c the bottom "lip" of the C-beam and/or the plate adaptor are flexing. You're using a horizontal plane to support a vertical load. Not a good solution.
If you support the trans w/a x member, that will solve the trans movement issue. You'll still have the issue of the reaction tq from the diff -the C-beam being a torque arm. Will that bottom lip be enough? IDK. I'd make the x-member, install everything, then stick a GoPro under there to see how much flex and movement you have w/just the 'bottom mount design". If it flexes too much, you'll have to figure out how to tie the bottom of the C-beam to the cut back top, get a new C-beam or make one specifically to be a torque arm...specific to FIT your car, is what I mean. I SUSPECT, that over time, the bottom lip of the C beam would flex, fatigue and fail...but I don't know for sure.
Old Jun 3, 2015 | 07:30 PM
  #45
Chevrolet12
I think the whole beam is flexing. The top is cut back I think just behind the bolt holes. And my thought is could I some way mount the c beam to the crossmember? Would that work if it's solid?
Old Jun 3, 2015 | 07:39 PM
  #46
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You said your engine is 550 hp. I'm going to ASSumer that it's 450 tq, trans is known, and I'm going to assume a 3.07 gear.
450x2.48x3.07=3426 ft lbs at the diff. C-beam is about 4' from the pivot point, so 4/3426=864 lbs.
Using those numbers, and not accounting for the "hit" of the converter, you're looking at a peak of ~900 lbs on that lower lip of the C-beam, lifting up on your x-memeber. Will that piece of aluminum hold that much? I think it would for a while....
Old Jun 3, 2015 | 07:40 PM
  #47
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The whole beam MAY be flexing since it's not mounted as it was intended; top and bottom tied together.
If it's flexing from just shifting into gear, there is no way it will hold the forces of full throttle launching.
Old Jun 3, 2015 | 07:43 PM
  #48
Chevrolet12
We are saying about 550 hp at the least.. Haven't got to the dyno yet. He thinks it may be more.. You are correct on 3.07 gear. And I was meaning maybe fabricate a different way to mount the c beam to the crossmember instead of just the lower lip.. I would prefer this to be a little more stout.
  #49
aDigitalPhantom's Avatar
aDigitalPhantom
I think the easiest thing to try would be to remove the rubber mount from the TH400, and mount what is left of the cbeam directly to the transmission.
Old Jun 3, 2015 | 07:45 PM
  #50
Chevrolet12
I didn't think it would hold and that's why I'm asking you for your advice. I would like to have a crossmember because it just seems stronger to me.
Old Jun 3, 2015 | 07:57 PM
  #51
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by chevyowner
I think the easiest thing to try would be to remove the rubber mount from the TH400, and mount what is left of the cbeam directly to the transmission. I didn't think it would hold and that's why I'm asking you for your advice.
First, I wouldn't remove the rubber mount from the trans, on a x-member. IMO, you'll break the trans casting from flex of the motor mounts (twisting), and frame flex. Or you'll be forcing the x-member to bend to accommodate that movement.
Second, I don't think the x-member is stronger than a properly mounted C-beam. Remember that a x member will be very long since the frame rails at that point in the car are very wide (rocker to rocker). So unless you seriously cut into the floor/interior to get a tall x member, it's going to be tough to get a strong, stiff x member that will double as a tq arm mount. If you're going to rearrange it so that you can properly bolt the C-beam to the trans, then you don't need the x member.
IF you move forward w/the X member, then I'd fab some kind of vertical element of the member, that would interface w/the C-beam on a vertical plane, where it has it's strength. Then bolt the C-beam, rigidly to that. Does that make sense?
Old Jun 3, 2015 | 08:02 PM
  #52
Chevrolet12
I am kind of lost on what you mean by that. I think I still have the piece that was cut off the beam. I may get that welded back on and see if I can get it mounted to the transmission. Any ideas on going that route. It seems like the best route for now.
  #53
aDigitalPhantom
I looked into it, but before I got very far I found what my problem was. On my car when you have the rear mono-spring, and the shocks removed the cbeam cant be installed.
For my car it would have required modifying the floor pans to make room for the crossmember.
For that I meant to use the cbeam, but remove the rubber mount is currently on the Th400.
Old Jun 3, 2015 | 10:06 PM
  #54
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If it were me, I'd fab a steel unit that bolts to the same flange as the trail shaft housing, extends rearward like 1/2 a box, meets and fits inside the C'beam...then bolt the beam to that.
Old Jun 3, 2015 | 11:19 PM
  #55
Chevrolet12
Ok I get what your saying. Should I cut the c beam down a bit shorter?
Old Jun 3, 2015 | 11:26 PM
  #56
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
IDK...Aren't you too short w/the THM400? I wouldn't cut it unless the 400 is longer than the 700 was.
Old Jun 3, 2015 | 11:28 PM
  #57
Chevrolet12
Ok yes.. I wasn't thinking. Also how does it not break the transmission without a rubber mount?
To Frame question..
Old Jun 4, 2015 | 11:17 AM
  #58
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The trans is strong enough on the vertical plane to handle those loads, and the C-beam is very weak torsionally, so any twisting forces (motor mounts flexing, frame flex, etc) is absorbed in the C-beem.
Old Jun 4, 2015 | 11:29 AM
  #59
Chevrolet12
Makes sense I am going to try to make a bracket and a half box to fit inside the c beam like you said. I will post more pics when I get it in and see your opinion.
Old Jun 4, 2015 | 12:24 PM
  #60
WVZR-1's Avatar
WVZR-1
If the original C-beam was long enough and could be used if NOT CUT I'd get another and start with a fresh C-beam that's not been whacked on. They're very inexpensive and there are many available everywhere very cheap probably very close to you. You want a D36/A4 C-beam if the older was long enough, if it was really very much to long you might want to get a D44 C-beam BUT they're not inexpensive and a little more difficult to come by. They're only slightly shorter than a D36 part but for an application that uses a D44 and an appropriate transmission it's much easier too use than to try and drill all four holes that are required and keep an appropriate alignment.
