fuel cell question
Old Jul 22, 2015 | 06:43 AM
phucking-low's Avatar
phucking-low
Default fuel cell question
I am wanting a fuel cell for my 84 corvette, can you mount the fuel cell inside the car it the very back of the of the trunk area and it be ok as far as passing tech at drag strips and auto x races. Just seems a ton easier to do it that way.
Second, on top of most fuel cells there are 2 vents. Where should these vents go, should they just be ran outside or do they need a sort of catch can?
Old Jul 22, 2015 | 10:33 AM
LT1_383's Avatar
LT1_383
I'm not sure if it has ever been done, but would not recommend it. From a safety perspective, you want the fuel cell on the other side of a fire wall. When things go wrong, the fire wall should give you some precious time to get out of the car.
During my stock car days, I recall a driver backing his car into the retaining wall hard. It was at the start of the race. Don't know what kind of fuel cell he was running or if it was ruptured, but it caught fire. That I won't forget. Also, I think a similar situation happened when Dale Earnhardt Jr. was driving one of the Corvette race cars. Last time I think he ever drove one.
Lastly, having the fuel that high in the car isn't good for your center of gravity if you plan to auto cross.
Old Jul 22, 2015 | 10:40 AM
rklessdriver's Avatar
rklessdriver
The fuel cell MUST be mounted on the opposite side of a fire wall to pass Tech.
It's really not a big deal. Remove the factory tank and build some mounts to hold the fuel cell where the factory tank was.
On my 84 I welded tabs to the fuel cell and mounted it to the rear bumper support and used a piece of square tubing to mount it at the front. This put the cap in a position so that I can even fill the fuel cell thru the original fuel door on the rear deck/body.
This is mine from the bottom and how I also mounted the fuel pump:
Will
To fuel cell question
