Cooling system
until around 226.The car is also pushing water out of the tank, when hot. I'm buying a system tester tomorrow to check the cooling system. Should the fans come on sooner. My 93 comes on around 200 and stays on until around 185.
They didn't operate at those temps from the factory.
1996 factory fan settings:
The PCM will command low speed fans ON at
104°C (219°F) and OFF at 98°C (207°F) and, high
speed fans ON at 109°C (228°F) and OFF at 103°C (214°F)
Note: On the '96, both fans run together (either low or high).
Also, Running the A/C will cause the fans to run.
Do some searching around here, and you'll find enough posts on this subject to keep you busy for days.
If you have the proper coolant mix and pressure cap, your coolant won't "Boil" until over 260°F
Your cooling fans will run at a slower speed when they first come on, and then move to a higher speed as the temps reaches approx. 228°F (based on the reading from the digital gauge).
While sitting in stop and go traffic: 217°F - 235°F
Moving at any speed over approx. 40 mph: 190°F - 200°
Here are a few to get you started:
https://www.corvetteforum.com/forums...lant-temp.html
https://www.corvetteforum.com/forums...s-too-hot.html
https://www.corvetteforum.com/forums...ioning-on.html
https://www.corvetteforum.com/forums...ating-but.html
https://www.corvetteforum.com/forums...-question.html
https://www.corvetteforum.com/forums...r-heating.html
https://www.corvetteforum.com/forums...-too-high.html
No. The '96 operates differently. RollaMo-LT4 covered it pretty thoroughly.
Aside from when the fans come on, the temps seem to be in the normal window. First item I would check or replace is the radiator cap and make sure it is the correct pressure for the car. I believe 15 pounds is the correct pressure cap.
As I mentioned in my reply above:
Plain water will boil at 212°F at sea level.
It is not boiling ,just pushing out.
I blew out to tank lines with air.I discounnected at the tank.I pushed water out of the tank on me. I also connected my scanner to the car the reading were only one degree off. It showed it was coming on at 227
I need to know this should the fans come low speed 212 or 227?
Thanks everyone
96 corvette
Of course if the pressure cap isn't operating correctly, the coolant will boil over at a much lower temp.
I recently found out that there is a city in Missouri called Rolla, so Rolla, MO. I thought his name was something like "rolling more" or similar to that...
I thought the same thing about "Rolla mo"
Sometimes I feel like I am not speaking English
I took his initial comment as the overflow tank because he said "The car is also pushing water out of the tank, when hot".
Why mention coolant pushes out of the surge tank when its hot because that a given and what should happen (just not excessively).
I may viewed it in my own way.......or is it me.
Yes, I live in Rolla, MO and have a '96 LT4 Corvette
So, RollaMo-LT4
And the temps I posted above for the '96 came right out of the '96 FSM
