4+3 clutch slave alignment issue
I have a 88 with a 4+3 Manual I'm restoring
I'm having a issue with the clutch slave cylinder and the fork
They don't line up
So as the slave pushes the rod it is pudding side ways
Like the fork is to short
How can this happen ?
It's a standard slave (from what I can see )
Someone has modified the rod
Any ideas
Thanks Dale
No not a new install
I did remove the boot and saw that the rod was on a massive angle
From the slave to the fork
So I remover the slave and saw some one has modified the rod
And the fork just seems to short by around 20 mm
Fork looks like it's on the ball
Will be removing box to have a look next week
Any chance of a pick of someone's to see the slave to the fork alignment ?
I have measured from the ball to the Center of the rod hold on the fork is 92mm
Is this correct ?
Thanks Dale
