Oil talk
Old Dec 11, 2015 | 07:19 PM
Blue Cheese's Avatar
Blue Cheese
Default Oil talk
Hey guys,
For a 1995 LT1 manual coupe, what is the grade and weight of:
Differential oil
ZF 6 Speed trans
Any upgrades from stock you might suggest?
Thanks!
Old Dec 11, 2015 | 09:22 PM
jv9999's Avatar
jv9999
Not again... please...
Old Dec 11, 2015 | 09:30 PM
Blue Cheese
Geeeeez.....sorry! Did the search function and didn't find.
Old Dec 11, 2015 | 10:39 PM
illenema's Avatar
illenema
Originally Posted by Blue Cheese
Hey guys,
Differential oil
ZF 6 Speed trans
Thanks!
I know the trans is 10w60 castrol synthetic
Old Dec 11, 2015 | 10:44 PM
Silver96ce's Avatar
Silver96ce
Don't apologize! Sometimes using the search function can be an exercise in frustration. Here are links to a couple of more recent threads regarding the ZF6 trans that may be of help to you -
https://www.corvetteforum.com/forums...-zf-trans.html
https://www.corvetteforum.com/forums...f6-issues.html
As for the rear gear oil, 75W-90, can be used and most of the aftermarket manufacturers make this grade in conventional and synthetic. Don't forget to add a bottle of posi additive.
If you want to use factory recommended fluids, here's a link to AC Delco site where you can input your make, model and year to see recommended oils -
http://chem.rjconlin.net/basepg.php?...=ACD&sOflt=TOS
Old Dec 12, 2015 | 08:46 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I found these doing a search, so I know it does work.
It can be frustrating though, until you get used to it.
https://www.corvetteforum.com/forums...eed-trans.html
https://www.corvetteforum.com/forums...ans-fluid.html
https://www.corvetteforum.com/forums...bmw-fluid.html
https://www.corvetteforum.com/forums...ion-fluid.html
https://www.corvetteforum.com/forums...best-lube.html
https://www.corvetteforum.com/forums...d-choices.html
https://www.corvetteforum.com/forums...id-change.html
I am using this in my ZF6 transmission:
http://www.amsoil.com/shop/by-produc...ont%2fmtf.aspx
Old Dec 12, 2015 | 07:15 PM
Blue Cheese
Thank you gentlemen. I guess the secret resides in using the good key words.
Old Dec 17, 2015 | 12:45 PM
Blue Cheese
Hey guys, I just called my chevy dealer and asked if he had posi additive. He said to use it only if I ran mineral oïl. Don't need it if I run Synthetic. What is the story on this?
What are you gurus saying on that?
Old Dec 17, 2015 | 01:17 PM
TorchTarga94's Avatar
TorchTarga94
Shoot Brad an email:
http://www.c66racing-synthetics.com/Contactus.htm
Order a couple quarts of this:
https://www.amsoil.com/shop/by-produ...ont%2fsvg.aspx
It already has the friction modifiers in it. Good to go!
As for the ZF6, I have been running Amsoil in mine for the last 30k miles with nothing bad to say about it. I am going to try Pennzoil synchromesh this time around since it is available locally and a lot less money. I have heard good things about it as well. My plan is to change the ZF oil once a year at the same time I do my engine oil.
Old Dec 17, 2015 | 02:10 PM
Blue Cheese
Thanks Torch! I found a couple of local amsoil dealers locally. Will give this stuff a go as well as for the Amsoil syncromesh 5W30 stuff.
So NO posi additive with the Amsoil severe duty??? You sure? LOL
This sounds like a cheap insurance Policy... http://www.amsoil.com/shop/by-produc...?code=ADATB-EA eventghough they write that Amsoil synth lube doesn't require it, it says it will do away with chatter on sound diffs. And mine being 20 years Young.... your thoughts?
Old Dec 17, 2015 | 02:17 PM
TorchTarga94
100%
Brad uses it in his race car and his daily driver CTS-V. I have had it in my Dana 44 going on 2 years now. No issues.
Old Dec 17, 2015 | 02:59 PM
Blue Cheese
Thanks man. That's the kind of hands on experience that inpires! Sold!
I've been driving on race tracks for over 20 yrs and I know some stuff, but Corvettes seem to have a particular thing about them from what I've discovered so far. I come from the dark side of the force and German wheels.... don't hold it agains me! LOL
Thanks again guys.
To Oil talk
