Flashing SYS light
Old Dec 20, 2015 | 02:11 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by antfarmer2
good job I hope you cleaned the connection block behind it.
OP I thought had a '94 (mentioned by someone I believe) and he's got a pair of under-hood fuse blocks with single lead pigtails to them that seldom require service and I don't believe they're exposed like the older jump-block.
If the OP has good terminals and cables pass a visual, he's had it "load tested" so I'd say he's likely fine.
Yours is a '94 isn't it?
Old Dec 20, 2015 | 02:33 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Yes I own a 94. The battery tested low under load. It had a slugish start up. The battery was over 7 years old. And with a new battery the light does not come on. And all the connections look fine.
Old Dec 20, 2015 | 02:38 PM
antfarmer2's Avatar
antfarmer2
I guess I need to take a closer look at my 94.
Old Dec 20, 2015 | 06:27 PM
DUB's Avatar
DUB
Glad to read you got it repaired.
I also hope that who ever installed the battery also did a visual inspection of the battery cable end...making sure that they were CLEAN and not corroded....and that they are TIGHT!!!
DUB
Old Dec 20, 2015 | 06:31 PM
DUB's Avatar
DUB
FOR WHAT IT IS WORTH:
Having the information on how to access and pull up data so IF you get a 'SYS' light flashing again...you will not be in shock on what to do. Doing this does not hurt anything IF you follow the instructions....and ANYONE can do this if they can read, comprehends and follow instructions. Because I KNOW I can not be the only one who can do this.
DUB
Old Dec 20, 2015 | 07:52 PM
Nowhere Man
DUB
I installed the battery my self all looked clean and new
Old Dec 21, 2015 | 06:12 PM
DUB's Avatar
DUB
DUB
Old Oct 18, 2019 | 08:01 PM
rmfris's Avatar
rmfris
5th Gear
2016 Corvette Z51
Old Oct 19, 2019 | 09:41 PM
belairbrian's Avatar
belairbrian
Glad you got it fixed. My SYS light was bad battery terminal bolt. Replaced both with Dorman help parts and haven't seen the light in a year or more.
My 2003 3500 pickup would tell you the battery was going bad by not turning on the dash. Drive 5 miles shut it off and restart and the dash came to life. Dealer told me he could program the dash voltage test out but I left it alone. Trying to convince the girl t the parts store I needed two batteries was a whole different adventure.
