Bogs in OD
Old Jan 5, 2016 | 05:43 PM
irishpete86's Avatar
irishpete86
Default Bogs in OD
Thanks for all the info on this board!!! I have been lurking for awhile and it has helped me fix a few issues. This one I can't really find a solution for. I have an '86 automatic and when it is in the OD position it always bogs when I first hit the gas when driving normal speeds. If I stomp on it this doesn't happen but if I accelerate normally when doing around 30 it bog's. There is no clunking noise or any other symptoms. If I put the shifter into D this never happens. Where should I start looking?
Old Jan 5, 2016 | 06:03 PM
antfarmer2's Avatar
antfarmer2
how old is your o2 sensor? and your injectors? clean your throttle body.
Old Jan 5, 2016 | 06:28 PM
Churchkey's Avatar
Churchkey
Put the trans in "D" around town. You are experiencing the wait time for the trans to unlock the converter & shift out of overdrive.
IMHO throttle response sucks around town when in OD, I always used "D" when driving in town when I had the base A4 89 vert.
Old Jan 5, 2016 | 07:17 PM
irishpete86
All new injectors and o2 tb clean
Old Jan 5, 2016 | 07:18 PM
irishpete86
That's what I have been doing because it is annoying as hell lol.
Old Jan 5, 2016 | 07:30 PM
DanielRicany's Avatar
DanielRicany
I believe the manual says to keep it in D until you reach 45 mph, then switch to OD.
Old Jan 5, 2016 | 08:05 PM
ex-x-fire's Avatar
ex-x-fire
I'd tighten up the tv cable one or two clicks , that torquey engine shouldn't have a problem driving around in od.
Old Jan 5, 2016 | 09:07 PM
Ismael S.'s Avatar
Ismael S.
Navigator
I'm having exactly same issue in my '86, its like the OD engage before it's time, looking forward to find the fix, I had an '85 a couple year back and it wasn't doing this.
Old Jan 6, 2016 | 01:24 AM
Cliff Harris's Avatar
Cliff Harris
I never put the trans into OD unless I'm going faster than 50 MPH.
Old Jan 6, 2016 | 09:27 PM
Ismael S.'s Avatar
Ismael S.
Navigator
Is everyone driving early C4 around town in "D" instead of "OD"?
Old Jan 7, 2016 | 10:31 AM
bjankuski's Avatar
bjankuski
I have an 1986 and the ECM locks the torque converter way to early in my opinion. It will go into lock-up at 22 mph and that is what cause the bog because the car shifts into overdrive at less then 30 mph and with the converter locked the RPM is less then 1000 and the car has no acceleration until you really push the throttle and the converter unlocks or the transmission downshifts. To solve this problem I changed the chip to raise the lock points of the torque converter in low gears and high gears to suit my liking. I believe I changes them to 42 mph lock points when the car was stock and it worked well.
Old Jan 7, 2016 | 02:50 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Hi OP.
Bjank is right here. He helped me deal with the same issue on my 85.
My solution, temporarily, was to simply disconnect the tcc lockup solenoid.
The tc never locks up. Which is the way cars were before tc's were invented. the result was that the bog dissapeared. and i lost about 1mpg.
So before doing anything really, I would unplug the harness to the tcc solenoid. Then drive around and see if its gone. Now you know its the tc as bjank has stated.
Then you can decide if you want to change it via a custom chip with different instructions to the tc than on the stock chip.
cheers. VT.
Old Jan 8, 2016 | 08:59 AM
aDigitalPhantom's Avatar
aDigitalPhantom
Just for clarification on this, but I'm guessing you are talking about lockup torque converters, and the older ones that don't lock.
Am I correct in guessing that the in the sentence "Which is the way cars were before tc's were invented." You were referring to a lockup torque converter?
Old Jan 8, 2016 | 09:22 AM
VikingTrad3r
Oil Producer
yes, that is what I was referring to. Sorry for being vague. That's the way original automatic transmissions were as far as I could find on the Internet. Then to help with bringing fuel economy up torque converter lock ups were created.
Old Jan 9, 2016 | 06:45 AM
kenmohr's Avatar
kenmohr
My 89will not shift in OD until I reach 37mph
Old Jan 9, 2016 | 08:01 AM
357L98's Avatar
357L98
I had the same problem with my 85. I had a guy on the Camaro board burn a new chip with the lockup set at 50 MPH, and it's perfect. No manual shifting required, and it locks up when you reach highway speed. I have heard that disconnecting the lockup is not a good idea, because it causes too much heat at highway speeds.
Old Jan 9, 2016 | 10:39 AM
VikingTrad3r
Oil Producer
do you have an email address or phone number for the person who burned you the chip? I would like to buy one for my 85 for the exact reason you did. Feel free to PM me
To Bogs in OD
Old Jan 9, 2016 | 12:56 PM
BOOT77's Avatar
BOOT77
I just shift into D when I want power, you gen more heat like said earlier in non-lock(more under power) and should use an add on cooler or your fluid & trans life will shorten.
Old Jan 9, 2016 | 03:16 PM
Ismael S.'s Avatar
Ismael S.
Navigator
Me too!
Old Jan 13, 2016 | 05:10 PM
Ismael S.'s Avatar
Ismael S.
Navigator
Does anybody else have a source for the chip mentioned?
Or can someone point me in direction of how to change speed in which torque converter locks?
