84 corvette not cranking
Old Feb 4, 2016 | 01:32 PM
Vettedude23's Avatar
Vettedude23
Navigator
Default 84 corvette not cranking
Hay guys new to the forum so if I'm posting in the wrong place I'm sry. I have a 84 corvette just got her about 3 months ago she pretty as hell but needs tlc. any way she won't start I changed the alternater to a Lil bit bigger amp out put and replaced the distributor cap on her she also has new spark plugs and wires. If any one has a 84 vette and had the same thing happen to u let me know how u fixed it please and thank you . any info well be appreciated. Ps she's carbureted not furl injected .
Old Feb 4, 2016 | 01:52 PM
antfarmer2's Avatar
antfarmer2
If it is turning over but not starting start with spark and fuel pressure. If it has spark shoot some starter fluid in it and post back.
Old Feb 4, 2016 | 01:53 PM
THE 383 admiral's Avatar
THE 383 admiral
congrats & Welcome. You need more specifics. Won't start is a vague term.
Can you confirm you have 12 Volt's, is your starter turning the engine over. Fuel to the carb, Spark at the coil & plugs.
Old Feb 4, 2016 | 01:57 PM
Vettedude23
Navigator
Thanks and sry. Yes I'm getting fuel and everything the engine turns u can hear that she wants to crank but she isnt .the man that had the car before me was a jerry reger and messed with alot but as for the fuel and spark plugs there getting spark and it's getting fuel (new fuel pump)
I think it might be a wire not grounded or something cause my lights a day before this happend kept going on and off by them selves tell I flipped the fog lights of lol
Old Feb 4, 2016 | 02:03 PM
antfarmer2's Avatar
antfarmer2
Try holding the gas pedal to the floor and try starting.
Old Feb 4, 2016 | 02:19 PM
Vettedude23
Navigator
Tried didn't work flooded it lol
Old Feb 4, 2016 | 06:01 PM
antfarmer2's Avatar
antfarmer2
That should have cleared it. Pull the vacumme line off the fpr and smell and look for fuel. If you can put a fuel pressure gauge on it and see the pressure and see how long it holds. just saw it has a carb dose it have a fuel pressure regulator? Tap on the top of the carb and see if the float is stuck.
Old Feb 4, 2016 | 06:44 PM
THE 383 admiral
Are you poisitve. From number one on the cap. You have the correct 18436572 dist to plug orientation? Your engine started before your Alternator, plug & wire upgrade???
Old Feb 5, 2016 | 11:49 AM
antfarmer2's Avatar
antfarmer2
Have you checked out you FPR yet? Smell your oil for fuel do not want to grenade it.
Old Feb 6, 2016 | 03:15 PM
pcolt94's Avatar
pcolt94
What kind of fuel pump did you put in? Carbonators only need a few lbs of pressure to operate. The fuel injection systems pumps can have 40 lbs of pressure which is too much for a carburetor. It would probably over ride the needle valve and flood the engine making it hard to start.
You might pull a plug and see if they look wet.
Make sure the firing order is correct as stated already and the timing is close to correct.
If it is trying to kick and start, then there is probably spark but I would check for it anyway.
Probably need to use some old school technology since you have a pretty basic engine now. Make sure the basics are there to get it started and not in excess.
Look down the throat of the carbonator, open the butterfly and see if fuel shoot out from the accelerator pump.
Old Feb 7, 2016 | 01:02 AM
Cliff Harris's Avatar
Cliff Harris
Most of the suggestions are referring to a EFI setup. He has a carb, so suggest accordingly...
How is the distributor set up for advance? An EFI system has ECM control of the advance through the ignition module output/input, so how do you handle spark advance?
Old Feb 7, 2016 | 04:40 PM
Vettedude23
Navigator
Default Update to the no crank issue
Hay guys sry been busy and thanks for all the help I appreciated all of it but found the problem it a wire that's connected to the positive wire on the batterie 5 bucks it's fixed starts right up now lol thanks agian guys
Old Feb 7, 2016 | 04:44 PM
antfarmer2's Avatar
antfarmer2
Good job! Was it a fuseable link?
Old Feb 7, 2016 | 04:46 PM
Vettedude23
Navigator
Yep theguy before me jay regged the poor car to run. Don't know why but it looked like he cut the Lil wire to put a butt end clamp on it... wierd but happy I found it lol
Old Feb 7, 2016 | 04:50 PM
antfarmer2's Avatar
antfarmer2
They need to be done right and think they need to be about 9 inches long. Do not want a fire.
Old Feb 7, 2016 | 06:05 PM
Vettedude23
Navigator
Hear yea on that thought it did this morning before I fixed it a few mins ago but didn't. Ps she cranks up on one touch now happy as hell lol
Old Feb 7, 2016 | 06:08 PM
Vettedude23
Navigator
Default One last question
Well since that no crank is fixed I had one last question motor don't know if it's a newer one or original but when it dies I was thinking of swapping it for a 96 zr1 motor any one know if it's alot of rigging or if it'll just fit right in. Ik I'll have to take the Doug Nash transmission out and replace it and plan to if I can do the swap lol thanks.
Old Feb 7, 2016 | 09:14 PM
THE 383 admiral
Good luck. The LT5 is a VERY hard engine to find. The price tag.
Runs from 15 - 25k engine only. A few years ago. Maybe you can find a totaled ZR1 and pick up the car cheap.??
I found you a 90 with 32k trans & harness for 10k shipping will be fun.
To 84 corvette not cranking
