1992
Old Apr 3, 2016 | 12:59 PM
jag5780's Avatar
jag5780
1st Gear
Default 1992
The car was pulled into the garage shut off would not start so changed the fuel pump and fuel filter now when
The car starts it won't idle unless you pedal it and I get a strong smell of gas an some backfiring .where do I start help would be greatly appreciated. Thanks
Old Apr 3, 2016 | 01:10 PM
antfarmer2's Avatar
antfarmer2
Put a pressure gauge on it and tell us the key on running and bleed off. Pull the vacuum line off your fpr and smell for fuel. And in your oil.
Old Apr 3, 2016 | 03:02 PM
pcolt94's Avatar
pcolt94
What made you replace the fuel pump to begin with. Did you diagnose it, what were the symptoms the pump was bad?
Is the gas smell burnt gas from the exhaust or raw gas?
Old Apr 4, 2016 | 11:07 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
did you change the fuel filter as well?
agree with the others to check your pressure at the rail
Old Apr 4, 2016 | 06:23 PM
93Rubie's Avatar
93Rubie
Old Apr 6, 2016 | 06:20 PM
1993C4LT1's Avatar
1993C4LT1
Do you know how to scan for codes? If you don't, here's how- put a paper clip in pins A&G in the obd1 port. Report back if you have any.
To 1992
