1984 corvette
Old Apr 30, 2016 | 09:56 AM
UserG's Avatar
UserG
Default 1984 corvette
My muffler fell off so we pulled other one.
Y pipe is in bad shape but with no mufflers you would think would be really loud
but it isn't
thinking cat is clogging up
after running car over a week with no mufflers she decided
to loose power.
were thinking catalytic converter instead clogging up.
Was thinking of just pulling cat n put test pipe but heard
you can clean catalytic converter s out.
any Ideas
Old Apr 30, 2016 | 12:11 PM
s carter's Avatar
s carter
but it isn't
to loose power.
any Ideas
Yes it can be but I don't recommend it I recommend replacement of it with a suitable Performance Cat that should be out there to avoid any problems with Vehicle Inspection problems if your state has such a thing. If you don,t have inspections well than find a Cat delete pipe or build/find a custom Exhaust, but the Cat you have now is full of a very Nasty Heavy metal compound and it wont do your health or the environment any good being polluted with that stuff, and doesn't come out easy.
I have heard that Metal Recycle rs will even pay for old Cat Converters
Old Apr 30, 2016 | 06:18 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Didn't you already ask this SAME QUESTION?
Old May 1, 2016 | 07:41 PM
Bendeco's Avatar
Bendeco
Maybe he didn't get the answer he was looking for? I found another topic by this guy called "running sluggish"
Old May 1, 2016 | 07:59 PM
UserG's Avatar
UserG
Didn't know I was only aloud to ask a question one time I asked again to make sure I was thinking straight.
Old May 2, 2016 | 07:56 AM
84Z51J's Avatar
84Z51J
George, I've seen you do multi-posts of same or very similar questions a few times now--the reason this bugs people (especially those who try to help) is that there's no continuous record of your problem & the steps you've actually tried in order to rectify it. People chime in with solid advice, and we never find out whether you followed or ignored it. It feels like a waste of time starting from scratch just so you can second guess the wording of your question...sorry!
Old May 2, 2016 | 01:51 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Didn't know I was only aloud to ask a question one time. I asked again to make sure I was thinking straight.
Why should we try to help you again, if you didn't respond to good suggestions the first time?
Old May 2, 2016 | 04:57 PM
UserG's Avatar
UserG
Okay here's my problem I'm waiting on my son to pull catalytic converter and rear y pipe off I got hurt at work I have severe lower back injury and legs numbness i can't get under car.
As soon as my son pulls parts off I will let you know what was the problem.
I'm sorry for not telling you what's up.
I'm injured hope you get some comfort out of this.
it will be possibly 2 weeks till fixed
I WILL POST SOON AS I KNOW WHAT PROBLEM WAS .
To 1984 corvette
