IAC count at zero
Old May 16, 2016 | 08:27 AM
  #61
MrWillys's Avatar
MrWillys
Originally Posted by 1993C4LT1
Honestly, I think I am getting correct info from the scan tool. IAC counts go up to 20 with AC running.
I would think then you could bring this to within 20 to 80 by adjusting the TB screw. With 40 to 60 being best.
Old May 16, 2016 | 03:24 PM
  #62
desertmike1's Avatar
desertmike1
That's what I'm thinking! does anybody know what the procedure is for adjusting the Base idle screw..
Old May 16, 2016 | 03:30 PM
  #63
MrWillys's Avatar
MrWillys
You're not using the minimum idle air procedure because you can read the counts. Turn the screw 1/4 turn counter clockwise and see if it will register counts. Let system balance and repeat.
Old May 16, 2016 | 04:46 PM
  #64
aklim's Avatar
aklim
There may be the FSM method but I don't like it much. For my L98, get it to final operating tem then I shut everything but the motor off. Read the IAC counts. If it is 0, it tells me the motor is getting too much air. I'd back the screw off by turning it counter clockwise, rev and see if the counts go up. In your case, I keep turning it out about a half turn at a time. Each time you turn it, rev and let it settle down. Target is 20-30 IAC counts.
Old May 16, 2016 | 05:37 PM
  #65
1993C4LT1's Avatar
1993C4LT1
Seems like this is my only choice. But I'll double check for vacuum and exhaust leaks. Desired rpm screenshot
Old May 16, 2016 | 05:47 PM
  #66
DaveP85C4's Avatar
DaveP85C4
Originally Posted by Cliff Harris
The EPROM code says to increase the IAC Counts a certain value when the A/C is turned on so as to maintain the SAME programed idle speed.
There ya go Cilff. I fixed it for you.
The idle speed does not "increase 100 RPM" with the A/C on. The counts increase to keep the idle speed the same with the additional load of the Compressor.
There is a similar sub-routine for coolant fan control. The ECM increases IAC counts just prior to engaging the coolant fan to minimize the idle droop from the increased load on the alternator when the fan load comes on.
Old May 17, 2016 | 03:40 AM
  #67
Cliff Harris's Avatar
Cliff Harris
The code specifies 100 RPM. It lets the ECM figure out how to get there, and the only way is to open the IAC.
There is a routine to increase the idle when the A/C is turned on to compensate for the compressor load. I have never seen anything related to coolant fans. I am looking at my '86 BUA code, so maybe there is something in the code for later years.
Old May 17, 2016 | 08:52 AM
  #68
MrWillys's Avatar
MrWillys
I show on your BUA that it adds 10 steps in the constants when AC is called for?
Old May 18, 2016 | 01:14 AM
  #69
Cliff Harris
That's only at startup:
LC631: FCB 10 ; Steps Added to Warm Park if A/C on during startup
Old May 18, 2016 | 08:31 AM
  #70
MrWillys's Avatar
MrWillys
And when warm and in Park it adds 10 steps.
