Throttle position sensor
Old May 14, 2016 | 02:30 PM
Bendeco's Avatar
Bendeco
Default Throttle position sensor
TPS how do you adjust it? I watched a YouTube video on it and he was trying to adjust it to .54 I think? How exactly do you adjust it? I saw the guy loosen it but not sure if he was sliding it up and down or back and forth trying to get it as close as he could. He pulled it apart and stuck 3 wires in it while adjusting is there another way?
If it's not close to spec will it give you less performance? What is the skinny on this? I am far from a mechanic as anyone, please fill me in.
Old May 14, 2016 | 02:53 PM
856SPEED's Avatar
856SPEED
The farther you slide it, the faster it will go.....or just take it off and save the weight..........
Old May 14, 2016 | 02:58 PM
Bendeco's Avatar
Bendeco
Your funnin me.
aklim's Avatar
aklim
What are you working on?
Old May 14, 2016 | 03:03 PM
Bendeco's Avatar
Bendeco
1985 TPI Vette auto.
Old May 14, 2016 | 03:08 PM
aklim's Avatar
aklim
The adjustable ones will be slotted. Non adjustable will be just 2 screw holes.
I believe you are adjustable and my 91 is non adjustable. Get the timing right first then set the TPS. Should be about 0.54V. People say that by setting it a little higher, it gets to the "off idle" point quicker but I haven't verified that myself.
Old May 14, 2016 | 04:07 PM
John A. Marker's Avatar
John A. Marker
Look down to post #6....
https://www.corvetteforum.com/forums...start-car.html
You should get it within .005 volts of high and low for the best performance. Many just set it for the idle of .054 volts and forget the WOT and loose top end. This sensor gives the computer the position of the throttle body blades. Setting the idle at .06 volts is supposed to give you a little edge off the line when drag racing (based on archive posts).
Old May 14, 2016 | 04:27 PM
WW7's Avatar
WW7
I adjust mine to around .58 on my 383 engine, I use a scanner to view the TPS while I adjust it..This makes it a 5 minite job...They sell a small harness that attaches to the TPS wires so you can use a voltmeter to read the TPS while making adjustments... If you do decide to set it higher then .54 just make sure you don't go much more then .60 or it will set a code...WW
Old May 14, 2016 | 04:38 PM
Bendeco's Avatar
Bendeco
Where is that little metal deal on it suppose to touch? I took the old one off and not sure where it goes it is like spring loaded.
Old May 14, 2016 | 04:50 PM
WW7's Avatar
WW7
The metal arm on the TPS has to engage with the one on the throttle body, this is how it gets a reading..As you can see in the picture the one on the TPS hooks under the arm on the TB...WW
Old May 14, 2016 | 04:57 PM
Bendeco's Avatar
Bendeco
Thanks a lot I had a check engine code and the one that was on there popped off when I took it off. Wasn't sure where it was suppose to go. That helps a lot
To Throttle position sensor
