Another clutch, another problem
As for the Shiftier if is bad they can be found
https://baltimore.craigslist.org/pts/5702426026.html
Definite slippage, though. 2nd gear, 2500rpm, cruising on a flat road at a constant speed with the clutch fully released and I can feel it slipping! Worse in other conditions as you'd expect. I don't believe the mechanic changed the fluid, so that will be something to investigate. He said it was a pain to do or something. That would be a simple fix if that's the underlying cause. I put my first miles on this clutch today, and after driving around a bit I determined that this can't be any kind of pre-break-in slippage. But the noise was coming from forward in the trans tunnel and correlated directly to whether or not my foot was on the clutch in neutral.
Put in a hydraulic throughout bearing 3/4 inch master cylinder a street strip clutch.
No problems
Prior in 3 years replaced 3 clutches. Put in New balanced flywheel on the 383 striker each time.
5 of my slave cylinders were damaged by over heating cats.
Good luck
I spent a lot of money wanted to blame mechanic "me"
If I ever go with a stroker kit, the Tremec seems like a pretty good option. But for now, a T5 would probably be beefy enough anyways.
The TKO600 seems like a fantastic transmission. However, it costs more than my car's worth and I'm afraid I have no pre-cats to cause such a problem. That is a lot of slave cylinders and flywheels, though!
For the expert on 4+3 Contact SK speed. They rebuild sell parts and gave me information on the phone no one else can.
They bought the last supply of the 4+3 .
I loved my 4+3 but the damage all the parts clutches and slave cylinders felt like could have bought 2 of the Tremec TKO 600.
The tko 600 with the hydraulic throwout bearing sitting on my tailgate was my answer.
If your paying someone to do this even more money.
My car is my money pit
Steve
Oh I paid $5000 for my vet. They wanted $9000 but the 4+3 Brock down on the test run. Worn out disk in over drive . We repaired them and some other parts. Had to drop transmissions and $200+ for parts.. A month later the clutch went out
Fixing electrical problems 5 years later.
Love my car.
T5 good transmissions
Also, did the shop check for evidence of any fluid contamination? Some overlook replacing the input shaft seal on the transmission. Just my $.02
Steve
Love my car.
