Heater Core Replacement
Old Aug 31, 2016 | 03:32 PM
CRTD's Avatar
CRTD
Default Heater Core Replacement
Hey are there any tricks to getting the heater core out of an 86 Corvette? Service info is terrible for this car. Any advice would be appreciated. Thanks!
Old Aug 31, 2016 | 03:43 PM
antfarmer2's Avatar
antfarmer2
You will be in pain and pissed off. Can you live with just bypassing it?
Old Aug 31, 2016 | 03:45 PM
divotdug's Avatar
divotdug
Probably not as bad as a 5th gen Camaro where you need to pull the windshield.
Old Aug 31, 2016 | 07:03 PM
roadking1's Avatar
roadking1
I did one on a 90 and had to pull the dash. I need to change a control module on top of the heater box and some said it could be done with out pulling the dash but I couldn't . changed the core at the same time.
Old Aug 31, 2016 | 07:14 PM
HAD2HAV2's Avatar
HAD2HAV2
Here are 2 pictures of the heater core, front and back.
Old Aug 31, 2016 | 09:36 PM
skyhawk50's Avatar
skyhawk50
I believe that when these cars were built, they had the heater core hanging on a hook and built the car around it.
Old Aug 31, 2016 | 10:19 PM
jv9999's Avatar
jv9999
Do some searching. There's been a couple of very good write-ups on it.
Old Sep 1, 2016 | 12:00 AM
Cliff Harris's Avatar
Cliff Harris
This an excellent description of what to do, with plenty of pictures:
https://www.corvetteforum.com/forums...post1569252027
Another take on this project:
https://www.corvetteforum.com/forums...post1543645426
Personally I thought it was easiest to remove the dash pad. I've done this job twice...
Old Sep 1, 2016 | 06:10 AM
ddahlgren's Avatar
ddahlgren
I think the engineers that designed the dash and parts accessibility should all be sent to Gitmo for water boarding.... They are evil people and bet they chuckled when done wanting to film the frustration of someone working on it. I can picture them sitting in a recliner with a cold beer and peanuts roaring in laughter!
Old Sep 1, 2016 | 12:42 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default heater core
I changed my 1985's heater core years ago. Just took my time and was not in a hurry to get it done. I did remove the top dash panel. Used my 1985's GM service manual for removal information.
When I drain my anti-freeze I remove the engine's knock sensor and having the cooling option remove the drivers side engine hose above the oil filter to get a complete drain.
Old Sep 17, 2016 | 04:34 PM
CRTD's Avatar
CRTD
Got it out today. Wasn't hard at all. The info here was very helpful. Thank you!
Old Sep 18, 2016 | 09:28 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i did my 87 this past spring. other than adding maybe a bit of light, i cant figure oit what removing the dash pad would have done.
maybe the &7 is diferent because there was a tight almost javket covering and you couldnt access or see the heater box or anything because this jacket thing covered it.
i do have a thread here where i showed what i did to a cheap socket i *think* it was a 13. it was used on the top of the cross brace to put it back together. it was too tight to use a full length socket and making it shorter worked great and it was a simple job.
To Heater Core Replacement
