Double dumb
Old Sep 24, 2016 | 02:14 PM
Redrod's Avatar
Redrod
Default Double dumb
After installing super ram, cam, new aluminum heads, new injectors, headers and getting chip burnt the 91 C4 was really starting to scream.
After a couple shake down runs around block I noticed an oil leak around valve cover. This is where double dumb starts!
As I was removing valve covers the thought occurred to me " disconnect wires on alternator it will be easier " but the thought never occurred to me " disconnect the battery"! Now Mr. Double Dumb has a clumsy moment and drops the wires sparks fly and smoke begins to rise from the area behind the battery . Upon inspection I found a fuse link blown so found fusible wire and repaired. BUT now car runs horrible! It sputters,pops, backfires! What did I miss???
Old Sep 24, 2016 | 11:01 PM
Redrod's Avatar
Redrod
Really need some help!! Please
Old Sep 25, 2016 | 06:35 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
sounds like you fried something, what wire did you replace, maybe your ecm.
Old Sep 26, 2016 | 04:58 PM
Redrod's Avatar
Redrod
replaced the fuse link on the red wire coming from the alternator! I'm afraid you are correct and i have fried the ecm! Don't you hate doing something stupid???
Old Sep 27, 2016 | 06:35 AM
bjankuski's Avatar
bjankuski
Check the codes from the ECM, does it allow you to pull the codes, does it show a item failure?
Old Oct 4, 2016 | 12:49 PM
Redrod's Avatar
Redrod
Got an ecm from advance and swapped prom but car still runs very poorly!
I looked at fuse links on jump start thermal and they appera ok! What you think about possible h fuse link blown?
Old Oct 4, 2016 | 05:15 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
In addition to looking for codes...
Ohm the injectors, measure voltage from the battery, and (if able) compare commanded advance to what you see on the damper.
To Double dumb
