Crossfire tuning
Old Oct 14, 2016 | 10:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Red1990VT
The Hypertech chip may or may not be right for your L83 engine. I can't recall if it was Hypertech, but at one of the aftermarket chip suppliers, I spoke with a tech who kept talking about a Mass Air Flow sensor. The L83 engine uses Speed Density, and does not have a Mass Air Flow Sensor. So, if you can make sure the Hypertech chip you have is actually correct for an L83 Crossfire engine. It might not be.
Some forum members have used the Hypertech in a CFI car and gone slower in the 1/4 mile. They put the stock chip back in and went faster, again.
Crossfire/L83 - which when running right is better than I think most people give it credit for...
Old Oct 15, 2016 | 12:26 AM
jose7740's Avatar
jose7740
I apologize in advance if I'm misinterpreting or misunderstanding anything that's been written, like the comment above...
The L83 engine sets its own timing via the computer, and the knock sensor mounted in the engine on the passenger side. The user does have to set the base timing, with a lead at the distributor disconnected. This is important, and might be at least partially the cause of backfiring. I recommend setting the base timing per spec, and then reconnecting the lead at the distributor. Then with the timing light, you can see the computer is advancing the timing per its programming.
And before you get much further into this, I'd really recommend balancing the throttle bodies. I've had two Crossfire engines, one on a Collector's Edition 1982, and one on a 1984 Z51. Both had issues, worse on the 1982.
Other things to check include the throttle position sensor, if that is not set correctly, the computer will be working with bad data, and garbage in garbage out.
The computer in the 1982 is behind the driver's seat right next to the battery. This brilliant design move results in not only no real air flow for cooling the computer, it also provides ample opportunity for fumes from the battery to seriously corrode the computer and connections thereto. Ask me know I know.
So, I'd check the computer and connections to it. Might be surprised to see how much caked on minerals there are on and inside the computer. Mine was in very bad shape.
Also, there is a vacuum hose running from the manifold to the Manifold Absolute Pressure sensor mounted on the firewall. Critical that not be leaking or missing. In fact, any vacuum leak will play hell with a Crossfire set up, since the MAP sensor checks vacuum and in turn the computer uses that info (among other sensor inputs) to set injector pulse width...
Another problem might be the Coolant Temp Sensor at the front of the block. Some of these used a single wire, grounding thru the sensor body. Bad idea, corrosion sometimes interferes with proper grounding. A bad CTS can throw everything off, not only on the L83, but on the L98, say in a 1990 behaving badly (again, how would I know that...). If the CTS is not right and the computer always thinks the car is cold, the extra fuel could conceivably cause backfires out the exhaust. Just a thought.
Getting an L83 to run right can be a hair pulling experience, and at best seems to be iterative. If you have a factory service manual, you can pull codes off the computer which can be quite helpful.
Hope this helps a bit, the FSM and this forum have lots of good stuff on Crossfire/L83 - which when running right is better than I think most people give it credit for...
I replaced all the sensors to include the map when I got the car back, have been using my FSM for everything, took the computer out and replaced the chip with the correct Hypertech model, like I said after today's adjustments to the timing, the car runs good, the only thing I have not done is to adjust the tbi's.
Old Oct 15, 2016 | 12:33 AM
jose7740's Avatar
jose7740
Oops, sorry for all the 1982 specific stuff, you are dealing with an 84 - that computer as I'm sure you already know is under the dash not near a battery.
Still, I'd check the Hypertech chip just to be sure. Otherwise the sensors between 1982 and 1984 are pretty much the same. And balancing the throttle bodies on either model year can make a bad running car work surprisingly well, on or off idle.
And pulling the lead at the distributor when setting timing is a must.
Best Luck with this...interested to know how it turns out.
The chip is the correct one, I disconnect the timing lead every time I adjust the timing, re- check it and reconnect it, still need to balance the tbi's but it is running better after bumping the timing.
Old Oct 15, 2016 | 12:36 AM
jose7740's Avatar
jose7740
Originally Posted by DUB
I assume you adjusted your TPS to the correct voltage value.
After your last series of adjustments....it the engine running as you want it to run???
DUB
I have the Tps set at .525 volts I think that is what the FSM says.
Old Oct 15, 2016 | 05:09 AM
corvettenorway's Avatar
corvettenorway
Old Oct 15, 2016 | 11:00 AM
Gibbles's Avatar
Gibbles
Check grounds as well, my car was super clean, and i think i was the first one to ever drive it in the rain...
i had grounding issues in the back, found out after a fuel pump upgrade.
i found nothing corroded, but still needed an extra ground strap to stable it out.
It also fixed my fuel gauge and weird random things with my turn signals...
Old Oct 15, 2016 | 05:59 PM
DUB's Avatar
DUB
Thanks for responding to my question about your TPS setting...and you set it correctly like the FSM states.
Is you backfiring still there???
DUB
Old Oct 16, 2016 | 12:44 AM
jose7740's Avatar
jose7740
DUB
I drove the car again today and did not notice anything abnormal seems to be doing ok, can not wait to get the Renegade to get a little more power. Does anybody has a header to recommend?
Old Oct 18, 2016 | 12:57 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
So, is it running OK now and NOT backfiring at WOT? I agree with Tom, the popping is more than likely a fuel issue (lean pop) or related. If you have access to a dyno, it would be nice to see what the A/F is doing through the RPM range and at high end. It would easy to see if you are going lean and increase FP to see how it responds.
IMO, DO NOT put the Renegade on your motor until you are 100% it is running absolutely correct...You may only create other issues and end up chasing your tail as it were.
10-12 degrees of timing should be OK, but maybe not. If it pings, back it off 1 degree at a time. FP is critical on a CF, ensure you are supplying the correct amount of fuel to feed the motor. The pump may be an issue as well. If you add a manifold, cam and new ECM before the motor is good to go, you WILL have issues. Just trying to save you a lot of possible grief down the road.
Also, if you buy a Renegade, thanks for your support. Good luck with your mods.
Old Oct 18, 2016 | 10:19 AM
jose7740's Avatar
jose7740
Thank's for all that, will post what happens down the road
