mini ram question
I haven't done that, largely because I like the very tall 2nd gear for autocrossing. Well, also because even with the stock gears and my "high rpm intake" I can't hook up 2nd gear on any street tire not intended for competition. First gear is hopeless. So more gear would really be a waste on the street for me. On a 60mph freeway (where, let's face it, we're all probably driving 70mph or more), if I just need to pass someone I leave it in 6th. Even though 2nd is good to 79mph at my stock 6400rpm redline, if I need to go fast I go to third and pull to really illegal speeds. It's all easy, and fun!
It all costs money...which was the other point frequently made here.
If your going to build a motor why would you want it only making power to say 4500 rpm's?!? We have diesels motors if you want a "stump puller".
https://www.corvetteforum.com/forums...o-results.html
Vic
No matter what intake someone chooses; the proper cam profile, heads, and rear ratio's need to be chosen to promote that intake.
Back in the 1980's we ran 410 sprint car engines with stock factory blocks and cast cranks that were externally balanced with 600 HP and 7500 RPM. Sure they eventually broke but they would last a season like this and that combination is way exceeding what you are thinking about doing.
Anybody with a short-runner intake and a soul.
I haven't hit 6500 rpm on the street with my Z. The quicker to the next gear; the quicker the acceleration. Plus, I was referring to the sound dcb at the higher rpm. In the younger years I learned that loud high rpms attract the men/women in blue.
Let me ask you this: Do you think an externally balanced 410 sprint engine has more vibration than an internal factory Chevy? I'm not talking about light-years difference, I'm just asking. In 2010, after talking to the local engine builders, I was told that a hand-built 383 would be better, smoother, faster -- and jump tall buildings in a single bound (as compared to my original 350).
I finally found one problem with the side-pipe mounts after a few years...but I had to buy it used, had no directions, and had to wait 2 years just to find that unique system. (I like pipes on the C3's!!!)
Currently, it has a mild miss or imbalance from 1600rpms - 2200rpms. It's factory smooth from 2200-3500. Either I have an injector imbalance, ported-intake imbalance, spark wire issue, or even an odd combination of these, motor build, and/or even the crank. Because I used a small cam, I expect it to be smooth. In fact, it will idle smooth a 750 rpms....like factory smooth.
I kind of think the imbalance has been there since close to the beginning. Certainly, it's had more of a "lawnmower" type vibration than the original 350. But, the AMOUNT of vibration is clearly rpm dependent. In some regions, it's VERY smooth. The fact that it's not ALL regions is why I have to ask....especially when my expectations were higher during the project.
I think I'm also asking if a self-ported intake could be the culprit? Just as much as I might be concerned about putting an HSR on it -- due to vibration, I also have to be honest and say I'm curious if the HSR will CURE the mild vibration I perceive. I am certain the ports are even and symmetrical in the HSR. I am also certain my hand porting isn't CNC perfect. Plus, the SLP does have it's limitation in the end port tubes (mounting bosses create a pinch).
I've had multiple people say my build is "unusual" -- but fine. And, I've also have as many say an unevenly cast (or ported) intake WON'T cause vibration. This is part of the reason I've grown to be uneasy about it. (Yes, I've asked the builder and he says to keep looking elsewhere.)
I gotta say it seems more logical to assume the intake causes the issue. Logically, I have some inclination to wonder about my [inherently] imprecise hand-porting...and it effects on engine smoothness. There are ONLY two cylinders monitored by O2 feedback due to the location of the bung in a Tri-Y header. Maybe those tubes are running 14.1 AFR...while another is lean enough to cause problem? Maybe I'm getting significantly more air through other tubes? Due to the nature of O2 feedback, it would be hard to retune the chip to run richer -- and see if it ran smoother. BLMs are always going to force the engine back to (what it thinks) is equilibrium.
That said, there's a "builder of fine engines" in Speedtalk (Walter Matlik) who thinks my motor is trash and will throw main bearings. Of course he said that 4 years ago...and is still be a butt-head poster about it today.
I don't know if the "best" are smarter....or sometimes just have an attitude? If he's the one that's "full-of-it", knowing it will help me make better decisions...and possibly convert to the HSR -- BOTH to see the difference in performance...and smoothness.
Maybe I'd be the one to show hand-ported intakes aren't all "perfection"! LOL
The unkind waves will lead to more flex and eventually the crank will show cracks somewhere because of this. This usually is evidenced by excessive #2 and #4 main bearing fatigue in a V8 engine.
Lower RPM and lower power generation will of course lengthen the time it takes for all this to happen
The effects of incorrect RADIAL balance can be seen in a crank which needs center counterweights, (or not), even though they won't change ROTATIONAL balance at all or very little at the most.
Those holes can be cosmetically ugly however, that is NOT the only problem with it.
