electric fuel pump pressure
Old Jun 21, 2017 | 01:57 PM
newbie2vette's Avatar
newbie2vette
Default electric fuel pump pressure
I am in the process of removing the stock crossfire system from my friend 1982 and replace it with FiTech system. Since the stock system already has a in tank electric fuel pump, I thought I would replace that with a higher pressure model; What year C4 has an electric fuel pump with 50 psi and greater? Thank you in advance.
Old Jun 21, 2017 | 02:06 PM
bjankuski's Avatar
bjankuski
85 and up, but you may need to check to see how much volume you need at 50 PSI. I am not sure if the stock pump will keep up with your combination and you may want to step up to a larger 254 LPH pump.
