96 LT4 A/C issues
I've few issues with the A/C.
The compressor was replaced, orifice tube was replaced, Freon was charged.
Two issues:
1) A/C is blowing cold. Once the RPMs drop to around 1,700, it starts blowing hot air. It does it just around the 1,700 - 1,800rpms. Below or over it works fine. Also when I press the clutch in and shift to neutral, for a few seconds it changes to hot air as well and than goes back to cold air.
2.) I'm using the A/C on the highest fan setting - I believe that's 9 or 10. Even with that, it's blowing air just like me new car at the 1st fan setting out of 4. What can be the issue? Can the lines be blocked by something? Or is this normal with every c4 vette?
The thing is even if the AC compressor stopped the air in the car will not get warm in an instant. It's almost like the blend door is changing position to hot but that would be highly unusual unless it was free and not connected.
It's hard to comment on the fan problem. If it is set at 10 the motor should be loud as heard from the engine compartment. Do all the vents work with the buttons?
Two issues:
blend door actuator under passenger dash...pretty simple to do yourself. Look it up
