3.33 gears with automatic
Old Jul 10, 2017 | 03:04 PM
Scooby92's Avatar
Scooby92
Default 3.33 gears with automatic
anyone running these gears with a 700r4? How do you like them? I will be getting my Dana 44 conversion with these gears done next week and was curious. Thanks.
Old Jul 10, 2017 | 07:42 PM
Kevova's Avatar
Kevova
It will be a whole lot peppier than the 2.59. Not so much, if you have a 3.07 I have a 3.73 but moving where highway speeds run 75-90 mph IMO I have a little too much gear.
Old Jul 10, 2017 | 08:47 PM
Scooby92's Avatar
Scooby92
It has the 2.59 gears now. With 3.33 I hope to get good acceleration with decent highway.
Old Jul 12, 2017 | 09:18 AM
mrodoc's Avatar
mrodoc
I don't want to state the obvious, but "too much gear" really depends on if your engine is built, torque converter, etc, and use. Is your C4 stock? I just got a DANA 44 for my 1994, not installed yet.
Cam is 227/234/.575/110LSA, 3000 stall converter and I'm lookig at 3.73 vs 4.11. I think I'll go with 4.11. Little to no highway driving. best of luck. let us know what you decide.
Old Jul 12, 2017 | 09:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Youll like it. those 2 series gears are friggin horrible
Old Jul 12, 2017 | 11:02 AM
sprink94's Avatar
sprink94
I have the 2.59 and found a 3.31 set that goes in a Dana 36 so I'm having one set up now.
I bought a used Dana 36 and having it re-built A~Z so my swap will be seamless.
Stay tuned...
Old Jul 12, 2017 | 11:03 AM
vader86's Avatar
vader86
3.33 is as low as I'd ever go with an A4, but I drive a lot of highway.
You will probably be very happy with it. I'd add a higher stall TC to that at some point.
Old Jul 13, 2017 | 12:45 PM
mrodoc's Avatar
mrodoc
Does anyone have real 1/4 mile times with 4.11 and other ratios like 3.73 or 3.33? I'm thinking of going from 3.07 to 4.11 on a LE2 build on a 4L60E with a 3000TC
(just picked up a Dana 44) I know it will burn more fuel and turn higher RPM on highway, but I do almost no highway. May take it to the strip, though.
Old Jul 13, 2017 | 02:08 PM
Scooby92's Avatar
Scooby92
Using a TH350 as a reference point to consider gears with the 700r4. 3.33 gears will produce roughly the same speed at 5,000 rpm as 4.11 gears in the TH350 in first gear. If my memory is correct at 5,000 rpm in second it will make roughly the same speed as 3.50 gears. Not a direct answer but some numbers I came up with using an online calculator. Hope it helps.
Old Jul 13, 2017 | 10:07 PM
pologreen1's Avatar
pologreen1
I'll say this... Just my opinion, because I do not have a lot of experience with this OTHER THAN driving several different gear sets, but only fun drives never for a week or whatever straight. Plus I can't figure it out myself and the damn things are so expensive compared to straight axles to change....
Like everything, it is up to YOU. I have been in a L98 c4 vette with :
-2.59 horrible
-3.07 better -auto / 4+3
-3.45 decent
-3.55 decent/good - 4+3 trans
-3.73 good
I had an '89 with light mods and 3.07 gears but a great stall for the car. I mean it was really matched well and I bought the car used so no idea what it was, but it made the car. Right now I'm trying to figure out that recipe. If I could have a matched combo like that in this car I would probably be happy. For an almost stock car it actually pulled really hard, and would beat on my Dad's almost stock '86 4+3 and he hammered through the gears and that thing felt like a torque machine too down low.
If you have an lt1 I think you could go lower for a street car if you think gears are what you are looking for.
L98 stock motor I'd think 3.55 max for sure and that will be a short burst of fun.
Each person describes it differently and without intended goals it's just a gear change.
I can say personally no way I would put a 3.33 in. Just me. It would not be low enough.
I don't race, and I don't do many high speed runs. I just like the snap and to jump on it once and while.
Fbody car guys always do gears, look around at their info.
I used to have mustangs and 3.73-4.10 was the PERFECT standard upgrade. (different animal though)
http://www.angelfire.com/fl/procrastination/rear.html
Old Jul 14, 2017 | 05:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
http://www.wallaceracing.com/Calculators.htm
Old Jul 14, 2017 | 05:38 PM
black_89_vette's Avatar
black_89_vette
mrodoc, I've heard a "rule of thumb" that for every 0.1 change in gear, you get half that (0.05) change in ET.
Example: Go from 3.33 to 3.73 is 0.4 gear change, yielding 0.2 second faster 1/4.
Just what I've heard referenced before.
So, from a 2.59 to a 3.33 is 0.74 gear change, maybe a 0.35 faster ET?
Old Jul 14, 2017 | 07:11 PM
sprink94's Avatar
sprink94
Back in the day we figured a second in the 1/4 mile was 4 car lengths...so .35 is a length and a half ? Visualize that and it becomes significant.
Old Jul 14, 2017 | 09:19 PM
bjankuski's Avatar
bjankuski
FyI, at 100 mph trap speed 1 second is 146 ft difference which is about 9 car lengths.
Old Jul 14, 2017 | 11:24 PM
sprink94's Avatar
sprink94
Ooops...I guess it was a half second !! LOL
Old Jul 15, 2017 | 08:47 PM
hemivett's Avatar
hemivett
Just went from 2.59s to 3.54s, and I am very happy with the improvement. 60 mph is 2k, and it will shred the tires. Just got to be careful leaving a stop light, and turning. It shifts into 2nd about half way through the turn, and if you are giving it too much gas, she'll be coming around. h
To 3.33 gears with automatic
