Camshaft Research and Question
If I got a set of Goodyears (vs Sumis), it would be even better.
Where I'm sure an HSR conversion would help is in the acceleration rate THROUGHOUT 3rd gear. (4th gets into 100mph range and doesn't matter for the street).
Matt...you think in terms of autocross where the course (and tires) would dictate the best combo. FWIW, my HSR was sold...then purchased back. In 2010, I SOLD to an auto-crosser who mounted it IN PLACE OF A LARGE TUBE TPI...then went back to the TPI for the classes he raced in. (At least that's what he said). I think there were too many turns AND it pulled better with the TPI out of them.
My heads/cam are better though. I've got more lift and similar overlap (112 LSA). I probably SHOULD have picked the 108 YOU have for a TPI. (Because it lowers the "hump"). But, I picked a cam that I thought would work equally well in an HSR or even a FIRST intake. (I sold the HSR AFTER building my combo....then bought it back. It's TOO CLOSE A PERFECT port match to my AFR heads NOT to try it some day.)
If you've seen a dyno for the FIRST, larger tubes do move the resonance wave higher. It performs pretty close to a superram. It has 200-300rpms lower peak but with more torque. Again...for me...the torque bump of the FIRST would be worth it.
Application is the issue. Race or Street or Race or Street?
Or...Auto-X!!!
The L31 camshaft cuts out too soon and with LESS torque production while the TPI extends that peak much further.
What I am looking for is a torque curve from my stock LT1 that replicates a TPI L98 with a ZZ4 camshaft
So, how do I achieve the results in the third and last torque curve graph with my LT1 and stock intake? I am thinking I need to use a TPI intake and either have a custom grind made that replicates the ZZ4 or just use a ZZ4 camshaft in my LT1 with the DART Pro 1 180cc heads, custom long tube headers, and necessary dynotune.
As much as the stroker option will give me what I seek, I am concerned about that city driving mileage loss. I want to remain around 15 mpg in stop-and-go traffic, while I stand to gain in highway mileage I will lose in city mileage and city mileage is what I encounter the most! This is why I am seeking a non-stroker build and why I am targeting the TPI intake.
How do you learn anything for lack of questioning? Man I have my own funny comment but let me not go there!
Attachment 48225963
Attachment 48225965
Attachment 48225966
[B]So, how do I achieve the results in the third and last torque curve graph with my LT1 and stock intake?
Also, I'm calling bullshit right now on the posted curves for the L98 with ZZ4 cam. No otherwise stock L98 (stock everything, including exhaust) with just a ZZ4 cam is going to pick up 78hp (assume about 225rwhp for a stock L98) and have a torque curve that's flat to almost 5000rpm, and barely tapers off for the next 750rpm. I mean, just look at the TPI graph in the C-P-C chart you posted just above that: it drops like a rock after about 3200rpm. I don't think that graph is from an all-stock L98 with only a ZZ4 cam swap. It might be an L98 with a Miniram or other short-runner intake, or various other mods, but it isn't all stock. Where did that chart come from?
Actually, if you look at the LT1 torque curve in the same C-P-C chart, it looks almost exactly like the ZZ4 graph you posted! That is, the stock LT1 torque curve is by far the closest to the ZZ4 curve you say you want to emulate. What you are actually asking for here is a torque curve typical of short-runner LT1 intakes and cams!
The ZZ4 torque curve was a modified L98 on https://www.thirdgen.org/forums/tpi/...hsr-211-a.html
Specs on engine
Stock 89 IROC shortblock w/100k miles
AFR 190 heads
Lingenfelter 211/219 cam w/1.6 RRs(.530/.560 lift)
HSR intake
I am researching all of this but I realize that if I do decide to put a TPI intake on my car, I need to figure out how to balance it's torque production on the low end with being encouraged to expand that torque curve by shortening the runners and totally porting out the intake for more airflow. At that point I would be better off keeping my LT1 intake while I think about it.
FYI, there is a very rare superram intake that was designed for LT1 engines, that would also help you.
Specs on engine
AFR 190 heads
HSR intake
To the rest of you all reading all this and laughing at me: before you even bother to say you told me so, I already know you did...
Well...this isn't the kind of powerband you've been blathering about! If this is the torque curve you want, then you sure as ******* hell don't want a TPI intake!!!
Oh, and my apology for screwing up on the graph when it was supposed to be for a ZZ4.
